block heater ??
Old Feb 9, 2004 | 06:22 AM
JBBNJ609's Avatar
Default block heater ??
ok so im looking at a link someone posted in the ITR forum and i see they hava block heater for sale only 30$ how does it work and does anyone have any pics
here is the link http://www.handa-accessories.c....html
Old Feb 9, 2004 | 06:27 AM
95TEG's Avatar
Default Re: block heater ?? (jason bouchard)
I am guessing it heats up the block for cold areas??? I dont know for sure.
Old Feb 9, 2004 | 06:46 AM
IN VTEC's Avatar
The heater is a resistance heater...kinda like a curling iron that you stick inside the the block.
It threads into the engine block coolant drain behind the header.
Old Feb 9, 2004 | 06:59 AM
JBBNJ609's Avatar
Default Re: block heater ?? (IN VTEC)
o , is it worth it , or should i not be intrested
Old Feb 9, 2004 | 07:23 AM
IN VTEC's Avatar
I guess it is.
The two biggest disadvantages are that it doesn't do jack for heating the oil, so it still takes longer for oil pressure to climb to fast idle max, and the other is that I wouldn't recommend it for use with forged pistons. I've got bore clearance issues, and it actually starts quieter when I don't plug in the heater, but it'll diesel for a second or two every time when I plug in the heater.
I run an Accusump, so the first issue really isn't an issue for me, but the second one can be.
Old Feb 9, 2004 | 11:21 AM
JBBNJ609's Avatar
intresting thanks for all the info man
Honderachinaldo
Jul 16, 2019 08:28 PM
kc-runner
Dec 3, 2009 08:21 AM
CO_CReX
Apr 29, 2007 06:44 PM
Paprika
Dec 10, 2004 10:24 PM
TurBoXBirD16
15
Oct 9, 2002 06:19 PM
