Differences between JDM and USDM Integras
Old May 31, 2004 | 07:02 PM
bighead06's Avatar
Default Differences between JDM and USDM Integras
I live in the Bahamas, so the majority of the used cars available to me are JDM models right from Japan. I am thinking about purchasing a Honda Integra SIR-G (equivalent of the GSR). My problem is that I want to modify the car and the least expensive way to do that is by using USDM parts out of the US. Will USDM GSR parts work on my SIR-G? Are there any large differences between the two cars? I'll be greatful to anyone who can help. Thanks.
Old Jun 1, 2004 | 02:17 AM
BlueIntegraBoy's Avatar
Default Re: Differences between JDM and USDM Integras (bighead06)
The only thing I see different is the dash, center console, and front end. All engine, suspension, exterior (except front end), and interior (except dash and console) parts should be the same.
Old Jun 1, 2004 | 02:22 AM
Dee's Avatar
Dee
Default Re: Differences between JDM and USDM Integras (BlueIntegraBoy)
Motor is tuned from the factory for 100RON fuel (~95octane). JDM SiVTEC/SiR/SiR-G has more compression than a USDM GSR. I have lots of USDM parts on my Teg. What parts are you looking to purchase?
Old Jun 3, 2004 | 06:27 PM
bighead06's Avatar
Default Re: Differences between JDM and USDM Integras (Dee)
Thanks for the help guys. I'm probably going to start with the basic bolt on's and then move up from there. Which do you think is better, turbochargers or superchargers? And what are there pros and cons? Thanks.
Old Jun 3, 2004 | 06:37 PM
ReggaePoweredDC's Avatar
Team Integra Articles -> Supercharger and Turbocharger
Old Jun 3, 2004 | 06:55 PM
luckyzz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">All engine, suspension, exterior (except front end), and interior (except dash and console) parts should be the same.</TD></TR></TABLE>
Note :
except SiR and higher , integras come with a SOHC engine
Old Jun 3, 2004 | 06:59 PM
luckyzz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bighead06 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help guys. I'm probably going to start with the basic bolt on's and then move up from there. Which do you think is better, turbochargers or superchargers? And what are there pros and cons? Thanks.</TD></TR></TABLE>
a Turbocharger uses the exchaust to compress the air going to the engine
superchargers use pulleys and some of the engine's hp to compress air going into the engine .
Old Jun 4, 2004 | 12:43 PM
Default Re: Differences between JDM and USDM Integras (luckyzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckyzz &raquo;</TD></TR><TR><TD CLASS="quote">
Note :
Yup, you are correct. I just assumed he wanted to compare the GSR to the Si VTEC/SiR-G.
Abius
11
Jan 21, 2008 03:51 AM
91efhbsi
Jul 2, 2007 08:48 PM
VTECcnIT
Feb 8, 2006 01:50 PM
i_HeArT_EgS
15
Jan 19, 2006 06:31 PM
Integra4lyfe
Nov 10, 2003 09:06 AM
