Finally got to the track
Old May 31, 2004 | 01:09 PM
sleepin91teg's Avatar
Default Finally got to the track
Hey i just got back from the track...i have a fully gutted DA, with I/H/E, lowering springs, short throw shifter and 15x7 race rims, with nitto 450's...car isnt running perfectly i know for sure it needs tuned...but i ran a 16.37, 16.35, 15.92 @ 88mph...does all this sound right? im thinking of throwing in a b16 swap, people are telling me i can get one for 500?
Old May 31, 2004 | 01:14 PM
JFG Kevin's Avatar
Default Re: Finally got to the track (sleepin91teg)
You can get a long block b16 for about 700...at least my friend cna get meh one for that price...but why...wheni have a b18c1
Old May 31, 2004 | 01:22 PM
TeamDOHCside's Avatar
not bad, with that trap you should be able to get 15.5's with a good 60'. Instead of swapping a b16 id either do lsVTEC or b18c. Just a word of advice.
Old May 31, 2004 | 03:26 PM
allmotrjdm's Avatar
dont get a b16 swap man, use what u got, and ur not going to be able to find a decent b16 swap for 500 bux
Old May 31, 2004 | 03:44 PM
HARI.'s Avatar
Default Re: (allmotrjdm)
yeah, why not go ls/vtec?
Old May 31, 2004 | 05:21 PM
94gsrsedan's Avatar
maybe a b16 head
Old May 31, 2004 | 05:35 PM
RPRacing's Avatar
i would hit the track again and run the hell out of the car to get a feel how to drive it down the strip. i took off a whole second between my first and second trips to the track.
learn to drive it
save your money
do your research
spend wisely
Old May 31, 2004 | 07:01 PM
xSCTYGx's Avatar
Default Re: (sucka306)
Fransisco, whatd you run if ya don't mind me asking?
Old May 31, 2004 | 07:34 PM
Frankintegra's Avatar
I have a 91 Teg and I had just a K & N Drop in and 15 x 7 and I did 15.906@87MPH I now have put in a LS/VTEC w/b16a Tranny, I/H/E and other little things on 16 x 7 with Kummos 712 and my friend and I were hitting it and I was slightly pulling on him! He has a PT Cruiser Turbo w/Stage 1 upgrade. Before the mod on his PT he was running 15.5@92 now it is 14.6 to 14.9 ET this number is from the PT website. I have not done a thing to the bottom end same 220 000 Kms pistions and conrods and I rev to 8000RPM and it feels amazing! I also have full interior and spare when I run! I just don't let up on that gas! I am able to go from a roll @ 2000 rpm and hammer it and when the tach gets to 5500 rpm the tire let loose then squeel in to 2nd then a quak in to 3rd! Also have a Spider Trax LSU ( limited slip unit) to give grip to both tires! I will be going to drag strip soon !
Old May 31, 2004 | 09:14 PM
pushinlsteg's Avatar
I ran 15.30 & 90 the first time I went to the track on 17's. I ran consistent 2.3 60 ft times, and 6.30-6.40 330ft times. I went again with LS mesh rims, and some stock tires..., ran 15.3 again but I couldn't hook up for **** compared to the tires on my rims. *shrugs* I have a 94 LS, with 140k on the clock, I/H/E. stock cat, never changed.
lxrd_vtec
Sep 8, 2013 11:53 PM
jorgejam2001
Sep 20, 2010 07:21 PM
ahron
33
Dec 31, 2007 11:14 AM
SouthernCrane
Apr 26, 2006 07:33 PM
JDMorgan
Apr 18, 2004 08:22 PM
