Any cause for concern?
Old May 28, 2004 | 03:38 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Any cause for concern?
Today, I was checking my fluid levels when I noticed a puddle of fluid inside the garage. Up until this point, my car didn't leak any fluids. So anyway, I dragged my fingers through the liquid (see photo). It seemed to have the same consistence as water, looks as well as a lack of oder.
So now, I roll out the jack to see where the leak originated. I didn't have to search much when I spot a hose / tube with a 90º bend that points toward the ground. I have some photos to support what I am talking about.
In the photo above, I have pinpointed the outlet of the leak.
This second photo is a close-up of the hose.
The third photo is where the leak landed.
I have provided within the photos what you are looking at. Here are a couple of questions I would like someone to field:
1. In your experience, is this any cause for concern?
2. Yes, it is a hose which transports a watery-like substance from point A (unknown) to point B (the ground). With that said, what is it?
Stupid answers need not reply. Thanks.
Old May 28, 2004 | 03:42 PM
Comp97GSR's Avatar
Default Re: Any cause for concern? (Jason M)
Have you used your a/c lately??
Old May 28, 2004 | 03:48 PM
Default Re: Any cause for concern? (Comp97GSR)
Yup. I have been using it quite a bit given the hot weather.
Old May 28, 2004 | 03:58 PM
mrwink's Avatar
maybe i am stating the obvious, but isn't that just water from the A/C?
Old May 28, 2004 | 04:08 PM
boostinb20vtec's Avatar
this has got to be a joke, right??? That's the tube that dumps the water from the A/C evaporator out of the car.
Old May 28, 2004 | 04:14 PM
Default Re: (boostinb20vtec)
Why would this be a joke? As far as I knew, this was a sincere concern. Be aware not everyone will be at the same level of knowledge as the next. If I knew I was a dump hose, I wouldn't have asked.
Old May 28, 2004 | 04:22 PM
vain's Avatar
it looks like its the condensation from the a/c you're fine.
Old May 28, 2004 | 04:40 PM
well, you have 2100 posts...just thought you would be a little more knowledgable. My bad
Old May 28, 2004 | 04:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">well, you have 2100 posts...just thought you would be a little more knowledgable. My bad</TD></TR></TABLE>
I thank you for your insight.
Old May 28, 2004 | 09:29 PM
FragSyndrome's Avatar
if it was an ac hose, then why would the liquid be messy? It looks oily to me - not like water.
Old May 28, 2004 | 09:57 PM
ferio 95's Avatar
Default Re: (FragSyndrome)
its just water trust me. no problem
Old May 28, 2004 | 11:17 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: (ferio 95)
Oh no, theres condensation on your floor!!
Old May 28, 2004 | 11:40 PM
debogsr's Avatar
Default Re: (ophdehEEzY)
Same thing happens to me all the time, AC water for sure.
Old May 29, 2004 | 06:52 AM
Alexander's Avatar
Default Re: (debogsr)
just a friendly reminder, make sure you turn your AC off when you turn the car off as well... just looks like water, its perfectly normal
Old May 29, 2004 | 07:39 AM
Brian_TII's Avatar
Default Re: (Alexander)
I'm not sure it's needed with modern cars. If you do leave it on and start the car, you will notice that you don't hear the A/C compressor click on until a few seconds after the engine has been running.
Old May 29, 2004 | 07:58 AM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">well, you have 2100 posts...just thought you would be a little more knowledgable. My bad</TD></TR></TABLE>
Not true. Patrick on here has more post then me, and we both dont know everything.
Old May 29, 2004 | 08:06 AM
Ditdogs's Avatar
Default Re: (ragejed)
this is why... (okie not really why but) i took out the ac in my car....
Old May 29, 2004 | 08:15 AM
EJ1 wilcox's Avatar
Your post count has nothing to do with how much you know...
There are plenty of people on here who are trial members that know a hell of a lot more than the rest of us...
Anyways, I think the fluid is just condensation from the A/C like the others said. As long as it's not oil or coolant, you are a-okay
Old May 29, 2004 | 11:54 AM
Jason, is it or is it not water? Feel and smell the liquid - what do you think?
Old May 29, 2004 | 12:03 PM
VTECorona's Avatar
Take a look at the fluid while it's still fresh. Soak some up in a towel if you can't see the color while its on the ground. Clear = good, green = bad.
Old May 29, 2004 | 12:52 PM
HuskerHybrid's Avatar
Default Re: (VTECorona)
dude if it comes out of a brown transparent tube, and is against your firewall it's your A/C condensation. if you sit at a red light you can see peoples' condesation drip from their cars...
Old May 29, 2004 | 12:54 PM
Xumarius's Avatar
Default Re: (HuskerHybrid)
this thread rocks
ramboPandA
Apr 20, 2015 06:01 AM
david420
Sep 9, 2010 06:48 PM
hassan21
20
Sep 21, 2007 03:09 AM
A340600
Sep 3, 2004 02:56 AM
DiscoStu
Jul 14, 2004 11:15 AM
