Help - problem with GC upper mount/AGX strut
Old May 31, 2004 | 06:41 PM
daewonder.'s Avatar
Default Help - problem with GC upper mount/AGX strut
any ideas how this could've happened? a friend of mine told me the same thing happened to his car minutes into driving with his newly installed koni yellows. he said it was an installation error but my struts were installed last august.
thanks for the help.
Old Jun 1, 2004 | 07:23 PM
daewonder.'s Avatar
Default Re: Help - problem with GC upper mount/AGX strut (B18Chillin)
someone help PLEASE.
Old Jun 1, 2004 | 08:09 PM
DOMKID's Avatar
did you forget the washers?
Old Jun 1, 2004 | 08:20 PM
z0om's Avatar
You need to put in #15 in this pic:
Old Jun 1, 2004 | 08:21 PM
Dan GSR's Avatar
Default Re: Help - problem with GC upper mount/AGX strut (z0om)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z0om &raquo;</TD></TR><TR><TD CLASS="quote">You need to put in #15 in this pic:
common mistake
Old Jun 1, 2004 | 09:21 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Help - problem with GC upper mount/AGX strut (Dan GSR)
Yes, that #15 washer is important. It seats on the shaft where it gets thicker. It allows the shaft to stay put under the fender area.
I hope you didn't put a dent in your hood....or your friend's hood, whoever's car that is.
Old Jun 1, 2004 | 10:34 PM
daewonder.'s Avatar
Default Re: Help - problem with GC upper mount/AGX strut (shamoo)
thanks for the help guys. i ended up just taking it out to look. believe it or not the washer was there but it cracked and began to get pushed farther and farther down the shaft. i banged it flat again, took the thicker washer from above the top hat (#6), put both on the lower side and replaced the top washer with 2 my dad had lyign around. i also put in 1/2 the old bumpstops since my cousin who orignally dropped my car left em out so "we could go LOWER." lol
there was a dent in the hood but it was to one of the ribs so it doesn't show on top. the hood was a little warped though. my dad and i pushed/molded it back as best we could.
thanks again!
Old Jun 1, 2004 | 11:20 PM
corona's Avatar
isn't there a special adapter that you need to have to use ground controls on konis??? maybe you're missing that. (if you haven't fixed it already)
sorwdfish
11
Aug 13, 2013 08:14 PM
EF_Tovi
Dec 18, 2010 02:41 PM
theskabeater
Suspension & Brakes
Jun 10, 2007 02:27 PM
DeeBeeTwo
11
Jan 7, 2003 02:46 PM
