weird vibrations
Old Feb 27, 2005 | 08:23 AM
Mike1486's Avatar
Default weird vibrations
this began recently.... inbetween 2000-3000 RPMs I get a weird vibration in my steering wheel. It creeps me out. It feel as if its on the left side of the car, and I can kinda feel the vibration in my pedal as well. And as with any stroke of luck my CV axle on my driver side went bad too... But if anyone could shed light on the vibration that would be of use to me... please let me know. Thanks!
Old Feb 27, 2005 | 09:51 AM
blkb18's Avatar
Default Re: weird vibrations (Mike1486)
Was the bad axel replaced or rebooted?
Old Feb 27, 2005 | 02:29 PM
Mike1486's Avatar
Default Re: weird vibrations (blkb18)
its not really the axle.... when i accelerate fast I get a vibration, and when im parked and idling, my exhaust pipes are literally going put-put. PLEASE HELP!
Old Feb 27, 2005 | 04:31 PM
natesgarage's Avatar
Stop accelerating fast. Check your timing. Do you know how the problem started?
Old Mar 3, 2005 | 01:29 PM
jbj-kustomz's Avatar
id check your plugs and wires; make sure your firing on all 4 cylinders. also maybe a clogged injector or fucked up wire to your injector. as said before, your timing could be messed up to.
Old Mar 3, 2005 | 01:38 PM
98lsskunk's Avatar
its normal for tegs to get a little shake around some rpms but not to where your teeth rattle. check the plugs distributor and wires, it could also be a problem with the drivetrain
808zrk
Jun 28, 2012 12:31 AM
ShinyNewPenny
Aug 7, 2010 07:11 AM
Jesterian
Nov 2, 2005 05:01 PM
black sohc civic
Jan 24, 2005 02:27 PM
