sparatic engine temp. gauge...
Old Feb 27, 2005 | 08:10 AM
Dumped DB2's Avatar
Default sparatic engine temp. gauge...
Ok, After driving a while yesterday, i go to pull into a friends driveway. I notice that all of a sudden my engine temp needle goes almost all the way to the H side but not all the way. SO im like what the hell? So I back out and drive away real quick. as soon as i drive away, the needle goes back down to normal. I then come back to his house and pull in again and the needle doesn't move. ANy ideas on what it could be. Less then 2 months ago, I had a new water pump, timing belt, thermostat, radiator, radiator hoses, and a valve adjustment done SO I don't think they could be it. Any got an idea?
Old Feb 27, 2005 | 08:16 AM
vtecfed's Avatar
Default Re: sparatic engine temp. gauge... (Pjct2ndGenTeg)
check the connection at the sending unit on the head. mine was loose and was causing the temp guage to max out and then drop down.
Old Feb 27, 2005 | 08:21 AM
Dumped DB2's Avatar
Default Re: sparatic engine temp. gauge... (vtecfed)
where on the head?
Old Feb 27, 2005 | 08:24 AM
vtecfed's Avatar
its really small. right by where the lower hose connects to the head.it only has one wire going to it. try to get somebody to get in the drivers seat and you jiggle the wire and have them see if the guage jumps.
Old Feb 27, 2005 | 12:11 PM
eymnewdc4's Avatar
that is how you fix it, but ive noticed this happen to a lot of people. happens to me all the time. but i know everything is legit, so i dont worry too much when it does it and im at idle.
Old Feb 27, 2005 | 07:14 PM
Dumped DB2's Avatar
Default Re: sparatic engine temp. gauge... (eymnewdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eymnewdc2 &raquo;</TD></TR><TR><TD CLASS="quote">that is how you fix it, but ive noticed this happen to a lot of people. happens to me all the time. but i know everything is legit, so i dont worry too much when it does it and im at idle.</TD></TR></TABLE>
how do u know everything is legit?
Old Feb 28, 2005 | 07:34 AM
eymnewdc4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pjct2ndGenTeg &raquo;</TD></TR><TR><TD CLASS="quote">how do u know everything is legit?</TD></TR></TABLE>
well....ok i dont know 100%. but the car never seems to run any different and ive never heard, felt, or found any problems. should i look into this further?
Old Mar 1, 2005 | 08:35 AM
Dumped DB2's Avatar
anyone else have any idea what my prob could be?
Old Mar 1, 2005 | 12:04 PM
Dumped DB2's Avatar
anyone?
Old Mar 2, 2005 | 10:01 AM
eymnewdc4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pjct2ndGenTeg &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
microfunk5
Honda Civic (2001 - 2005)
Sep 21, 2010 07:45 AM
caseyliffick
Apr 7, 2010 02:21 PM
Astig
Apr 16, 2007 10:32 AM
lude1888
Mar 3, 2006 08:42 PM
jdm_gsr
Dec 18, 2003 03:03 PM
