gsr leaking oil
RTFM
gsr leaking oil
So far I have reaplaced:
the o-ring on teh breather box
the pcv valve
both hoses to the breather box
the distributor o-ring
both vtec solenoid gaskets
the o-ring behind hte oil cooler
i still ahve a drip of oil....what is left? I know my headgasket and valve cover gasket are solid, and I amy do the oil pan gasket soon, but is there anything else on teh back of hte block that can leak???
the pcv valve
Re: gsr leaking oil (jdmhonda)
clean the entire engine up...let it sit for a few hours...then get under there and look to see where the drip is coming from.
RTFM
drain plug and washer are both fairly new and the leak is coming from above the oil pan line.
i have cleaned the engine up onc with simple green and a hose and twice with carb cleaner.....with the webbing ont eh block i cannot see where it realyl comes from without taking the manifold off. i was really hoping that someone would know if there was another location for a plug or something that woud possibly leak oil.
blacktibby07
21
02-03-2011 04:42 AM
