Gas poll
Old Mar 2, 2005 | 11:09 AM
BLK99VTECR's Avatar
Default Gas poll
Whats the best 93 octane brand to run in a GSR on track day: Chevron,Shell,Exxon,BP,Sunoko?.
I just curious cause im trying to make sure my car is running as best as it can for a upcoming track meet, and I also plan on runnin a little octance boost to.
Old Mar 2, 2005 | 11:32 AM
3.504's Avatar
Default Re: Gas poll (BLK99VTECR)
octane boost is crap and you dont need the extra octane in your car unless you're going to raise boost or swap to a heavier jet. gsr's require 91 octane and thats the stuff you should run.
as for a good brand of gas, they're all the same gas. seriously, theres pipe lines that deliever petroleum products all over north america, the companies put 1 barrel in 1 side and a barral comes out the other, its not the same barrel. its just the same quality. each different brand adds there own additives. i personally trust mobile, shell, and bp. as for the cheaper stations (red apple and other no namers) i dont like to buy gas there.
remember, your car requires 91 and the only reason to run higher is if you have a reason to.
Old Mar 2, 2005 | 11:34 AM
BLK99VTECR's Avatar
hmm i will keep that in mind
Old Mar 2, 2005 | 11:42 AM
Haleiwa-Brando's Avatar
Default Re: Gas poll (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">octane boost is crap and you dont need the extra octane in your car unless you're going to raise boost or swap to a heavier jet. gsr's require 91 octane and thats the stuff you should run.
remember, your car requires 91 and the only reason to run higher is if you have a reason to.</TD></TR></TABLE>
Well said! I agree.
Old Mar 2, 2005 | 09:55 PM
matto2413's Avatar
ive been putting 89 in my GS-R but it really requires 91? i remember when a couple times that i did actually put 91 in my car just hate it right up. (91 is like 2.25 a gallon....can you say GOD DAMN)
Old Mar 2, 2005 | 09:58 PM
00s2KkId's Avatar
Default Re: Gas poll (matto2413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matto2413 &raquo;</TD></TR><TR><TD CLASS="quote">ive been putting 89 in my GS-R but it really requires 91? i remember when a couple times that i did actually put 91 in my car just hate it right up. (91 is like 2.25 a gallon....can you say GOD DAMN)</TD></TR></TABLE>
see those little words on ur cluster that say PREMIUM UNLEADED FUEL ONLY...
i put 93 in my gsr cuz the rating are either 87 89 or 93...no 91..owell
Old Mar 2, 2005 | 09:59 PM
SYTFU Tommy.'s Avatar
ummm u need 91 my friend...and no i cannot say god damn to that price since its so high. that is like the price we are paying for regular = 87octane here.that is consider cheap already for 2.25......
Old Mar 2, 2005 | 10:02 PM
gsr_to_the_MAX's Avatar
Default Re: Gas poll (96GSRkId)
i use either shell, 76, or chevron gas and on 92 octane. i follow orders from my car and it orders me to use premium unleaded only
Old Mar 2, 2005 | 10:21 PM
matto2413's Avatar
my cluster doesnt say PREMIUM UNLEADED FUEL ONLY, lol. its a LS, did a swap with a GS-R. does that octane booster **** really work
Old Mar 3, 2005 | 04:34 AM
..::91TEG-G2::..'s Avatar
Default Re: Gas poll (Haleiwa-Brando)
well dont some, cheap gas company's have a higher water content in there gas? even at higher octane too.
Old Mar 3, 2005 | 04:41 AM
fujii13's Avatar
Default Re: Gas poll (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">well dont some, cheap gas company's have a higher water content in there gas? even at higher octane too.</TD></TR></TABLE>
the thing you have to watch out for is the additives. a lot of the cheaper companies use additives to increase the octane rating, but it's really crappy gas
Old Mar 3, 2005 | 11:52 AM
3.504's Avatar
Default Re: Gas poll (fujii13)
actually its not the water you should worry about, but the other additives. water is there to displace so they can have more total liquid to sell. the other additives that they put in are kinda crazy. there are quite a few detergents and an additive to keep the volatility down in summer and volatility up in winter, to keep it from freezing, theres additives to absorb and isolate water in the fuel system. most of these additives are different alcohol's. alcohol has a tendancy to raise octane and absorb water when in gasoline, but if theres too much (like the octane boosters add) it actually does harm to the fittings, lines and you filter. i dont suggest adding any additive regardless of what it is.
i dont trust seafoam and all that other garbage. if you can get it at advanced at it claims to be some "mechanic in a can" then its probably garbage and your better off just fixin the problem then trying to mask it with one of these products
Old Mar 5, 2005 | 06:06 PM
tkHBseries's Avatar
You might want to stop putting 87, 89 or the reg. stuff in...i used to do that with my prelude (vtec) for about a year and a half....my rings were trashed...lost compression and f*cked up every thing internally! Just my experience
Old Mar 5, 2005 | 07:42 PM
redINTEGRAdriver's Avatar
your lucky, gas around san diego for 87 is 2.23-2.40 and thats 87. out premium 91 is around 2.50, so we're the ones that have to say god damn, not you. why doesn't cali offer 93 octane ? whats the reason for different octane levels in different states?
Old Mar 5, 2005 | 08:03 PM
Default Re: Gas poll (redINTEGRAdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkHBseries &raquo;</TD></TR><TR><TD CLASS="quote">
You might want to stop putting 87, 89 or the reg. stuff in...i used to do that with my prelude (vtec) for about a year and a half....my rings were trashed...lost compression and f*cked up every thing internally! Just my experience </TD></TR></TABLE>
actully it went up already. its like 2:30+ for a gallon of regular also. remember, its at least 10cents more in san franisco. god, everything cost too much in the bay area...
Old Mar 5, 2005 | 09:03 PM
sabotage7's Avatar
i agree with everything 3.504 has said so far.....and i always use 93 octane mobile, never had any lower octane in her..... and my compression is purrrrfect
Old Mar 6, 2005 | 05:12 AM
highrevin2k's Avatar
Default Re: Gas poll (sabotage7)
I say keep using 87 or 89 octane in your GSR your car will thank you latter by knocking
Old Mar 6, 2005 | 08:20 AM
MikeTV
Guest
Posts: n/a
Default Re: Gas poll (highrevin2k)
I only trust Sunoco in my car....they have some pretty badass racing gases, and it might be my imagintation but my car runs so well with it .....
Old Mar 6, 2005 | 08:38 AM
ernald711's Avatar
91 chevron
jdmlude_dude
Feb 17, 2006 06:22 PM
andysila
Mar 2, 2005 03:25 PM
BLK99VTECR
Feb 27, 2005 09:20 PM
TheHater
Feb 13, 2003 04:29 PM
dustin
Jul 30, 2001 07:59 AM
