Battery Question!
Old Feb 27, 2005 | 01:14 PM
sleevedgsr's Avatar
Default Battery Question!
I need instructions on how to take out a 95 Acura Integra GS-R battery believe it or not I have never done this!
Old Feb 27, 2005 | 01:34 PM
94DOHCGsr's Avatar
Default Re: Battery Question! (tested positive)
first take off the hold down plate. Then disconect the neg cable first. Make sure u have ur radio code. Then take off your pos. cable. Pull out batttery. I think our battery code is Mt-51r for interstate. Then clean battery clamps with wire brush, water and baking soda. Then dry them off and reconect pos. terminal first. Then neg terminal. Finally clamp down the holding bracket. it easy. Takes a few min.
Old Feb 27, 2005 | 02:09 PM
LSvtec03's Avatar
Default Re: Battery Question! (94DOHCGsr)
have the battery code BEFORE taking of the negative terminal. it will be a 5 or 6 digit numerical code.
Old Feb 27, 2005 | 03:30 PM
sabotage7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DOHCGsr &raquo;</TD></TR><TR><TD CLASS="quote">first take off the hold down plate. Then disconect the neg cable first. Make sure u have ur radio code. Then take off your pos. cable. Pull out batttery. I think our battery code is Mt-51r for interstate. Then clean battery clamps with wire brush, water and baking soda. Then dry them off and reconect pos. terminal first. Then neg terminal. Finally clamp down the holding bracket. it easy. Takes a few min.</TD></TR></TABLE>
i can't believe you've never done this before! i've seriously done it at least 100 times bc i used to have to do it for my job! btw, the batteries on our cars are the easiest out of all the cars in my opinion so you're lucky your first battery install is such an easy one!
have fun!
socialgirl
Dec 9, 2017 08:53 AM
poprocksncoke
17
Aug 22, 2014 08:19 AM
Tom's hybrid
Honda Civic (2001 - 2005)
Jan 7, 2013 04:02 PM
ken00si
Oct 25, 2006 12:28 PM
