which trans
Old Feb 28, 2005 | 03:45 AM
1998teg's Avatar
Default which trans
well i have a 98 ls with 107k on it and the automatic trans is starting to slip a bit so im thinking of dropping in a manual transmission. at first i was gonna do the engine and trans but the engine runs perfect and find no reason to get a new one yet. when i do put in a new engine it will most likely be the b18c(gsr) so i want the trans im goin to put into it now to be compatible with the b18c motor as well. im not sure if an ls tranny will hold or if i should get a gsr trans, but will the gsr trans match up with the ls motor. im not too sure how a trans and motor match up and if they are interchangeable. if u have any comments please fill me in.
Old Feb 28, 2005 | 04:41 AM
honda011's Avatar
Default Re: which trans (1998teg)
put a b16 trans in, it has shorter gears, unlike an ls trans which is longer, and the b16 trans is also shorter than the gsr..
Old Feb 28, 2005 | 06:03 AM
chadwick16's Avatar
gsr trans will fit an ls motor but i would go with b16
JDM-sol 89
Mid-Atlantic (Sales)
Apr 6, 2009 11:29 AM
