Help LS vtec
Old Mar 20, 2005 | 08:58 AM
aph7824's Avatar
Default Help LS vtec
I'm about to buy an Integra with a LS motor, would someone guide me to put a b18c head on it? How would it fit? would it break out as much horsepower as a B18c1 would?
Old Mar 20, 2005 | 09:26 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Help LS vtec (aph7824)
search "lsvtec" SO much info
good luck!
Old Mar 20, 2005 | 10:24 AM
Spectrum24x's Avatar
Default Re: Help LS vtec (DAantagonist)
what year integra did you buy?
if its a 90-93, you need to come join the DA squad, we'll help ya
Old Mar 20, 2005 | 10:32 AM
natesgarage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">search "lsvtec" SO much info
good luck!</TD></TR></TABLE>
Old Mar 20, 2005 | 11:04 AM
aph7824's Avatar
Default Re: Help LS vtec (natesgarage)
I searched but I didn't find the EXACT thing I wanted.. Its a 98 LS.. and I want to put GSR or Type R head on it, would it be the same horse power as the GSR or type R?
Old Mar 20, 2005 | 11:07 AM
no, completely different.
it'll work the same as any ls vtec setup, just different numbers
Old Mar 20, 2005 | 12:14 PM
I would have to say it depends on what engine mods you choose to do...from stock head/stock block...MAYBE the same as GSR. With cams, v/t, p&p etc you have a chance to make MORE than ITR.
Search and read what people have built.
Old Mar 20, 2005 | 12:19 PM
Default Re: Help LS vtec (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">no, completely different.
it'll work the same as any ls vtec setup, just different numbers</TD></TR></TABLE>
Here's a good example:
https://honda-tech.com/zerothread?id=1144758
Old Mar 20, 2005 | 01:43 PM
My LS/vtec build should be done tuesday,
its definetely gonna put out more then a type R.
of course its costing me around 5k for parts, labor and tune.
12.7:1 compression
Old Mar 20, 2005 | 02:03 PM
IggyBcool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">My LS/vtec build should be done tuesday,
12.7:1 compression </TD></TR></TABLE>
i mean my lord 5k on a ls/vtec.....for that amount of money u could have bought a b18c5 that is alot more reliable and plus still be able to mod the c5..... i don't understand why people pour so much money into a ls/vtec.
Old Mar 20, 2005 | 02:06 PM
Default Re: Help LS vtec (99LStegra)
no no my friend, the reason i poured the 5k is because it will be just as reliable as a b18c5.
"Ls/Vtec is reliable if done right"
im doin it right my friend.
and i could still mod it.
plus a c5 would cost about the same, if not more and i could waste a c5 with this setup
Old Mar 20, 2005 | 04:42 PM
IggyBcool's Avatar
i mean all u would have todo is stick some skunk2 stage twos or some crower 404's then have a p28 ecu chipped and have the revlimiter raised to 10k and it would be on like donkey kong for ur ls/vtec
Old Mar 21, 2005 | 01:57 PM
Default Re: (99LStegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LStegra &raquo;</TD></TR><TR><TD CLASS="quote">i mean all u would have todo is stick some skunk2 stage twos or some crower 404's then have a p28 ecu chipped and have the revlimiter raised to 10k and it would be on like donkey kong for ur ls/vtec</TD></TR></TABLE>
I don't think it's that simple on the rev limit part. I would say you would need to keep your revs to around 8k, depending on what rods and pistons you use it could be higher. With ARP rod bolts...8k...with aftermarket rods and pistons...maybe 9k. My LS/V JUST got delivered today. They're finishing the assembly now. I built mine with ARP rod bolts and stock rods. I won't be reving mine past 8k unless on the track. Be safe and know what your build limits you to. That's why we all say SEARCH and RESEARCH .
BTW...chipping the ecu is not the way I would do it. please use Hondata .
Old Mar 21, 2005 | 09:48 PM
Default Re: (DAantagonist)
hondata
only way to go, even if its a stock honda.
i've seen it produce 10whp on a stock prelude.
Old Mar 21, 2005 | 10:05 PM
98lsskunk's Avatar
these people and their (ls-vtec relaibilty issues) if the person that puts the damn thing together knows what they are doing it will be just as reliable if not more than any other b-series motor.
Old Mar 21, 2005 | 10:29 PM
Default Re: Help LS vtec (98lsskunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lsskunk &raquo;</TD></TR><TR><TD CLASS="quote">these people and their (ls-vtec relaibilty issues) if the person that puts the damn thing together knows what they are doing it will be just as reliable if not more than any other b-series motor.</TD></TR></TABLE>
AMEN!
i dont plan on worrying about my ls/vtec...
Old Mar 22, 2005 | 06:14 AM
agreed
Pabs626
Sep 15, 2007 12:35 PM
brian3676
Sep 27, 2005 09:58 PM
xgenn786
Sep 25, 2005 10:28 PM
92integra13
Feb 17, 2005 09:51 PM
mxler8
Jul 27, 2004 07:57 PM
