Radiator
Old Mar 21, 2005 | 10:53 AM
hwtfan's Avatar
Default Radiator
my 96 gsr's radiator cracked and needs replacement what one should i get? and is the gsr radiator differ from the normal tegs?
Old Mar 21, 2005 | 11:02 AM
timmy8151's Avatar
Default Re: Radiator (hwtfan)
Just get a OEM style replacement from: http://radiatorbarn.com . They're about $100 shipped and have a lifetime warranty. I've been running one of these radiators for about 80K miles without any problems.
Old Mar 21, 2005 | 11:18 AM
5 Speed AP2's Avatar
No difference in radiators from LS, GS, or GSR. And the install is basic bolt on/bolt off.
Old Mar 21, 2005 | 12:47 PM
greaseball's Avatar
i've got a used(20k miles) gs-r radiator i can sell for $60 shipped. it is in great condition. i put an aftermarket koyo in so this is just taking up space. lmk.
Old Mar 21, 2005 | 01:50 PM
eK9aT10pSi's Avatar
get one from autozone, around 100$ and lifetime warranty
Old Mar 22, 2005 | 07:41 PM
julian_gq's Avatar
no difference in models but there is a difference between 5 speed and auto
Old Mar 22, 2005 | 08:44 PM
VtecAdvantage's Avatar
I was on the same boat as you
What ever you do.. watch out for aluminum radiators - they're tempting
one of the most common radiator myths is that aluminum is always better.. don't get me wrong.. there are some aluminum radiators that are designed for just racing but they also are more susceptible to acid corrosion and need to be beefier to keep the motor cooler. They are a little bit ligher but not much of a difference
Like the other guys said - go with the OEM replacement or something similar with a warranty
Old Mar 22, 2005 | 09:02 PM
spriggan's Avatar
check out my sig
Old Mar 22, 2005 | 11:09 PM
SonicBlueTeg's Avatar
Default Re: Radiator (GSRStreetRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRStreetRacer &raquo;</TD></TR><TR><TD CLASS="quote">I was on the same boat as you
yea not to mention u would need slim fans to get em to fit in the teg..
i have a koyo oem replacement.. after my radiator cap blew up prematurely due to the mugen hi pressure oil cap and not upgrading the fan switch & thermostat.. tried to smush the 55mm core all aluminum in the teg.. but it was a no go without fal fans ... tossed on a koyo, mugen fan switch & thermostat since.. problem resolved..
Old Mar 23, 2005 | 06:25 AM
greaseball's Avatar
Default Re: Radiator (SonicBlueTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicBlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">
yea not to mention u would need slim fans to get em to fit in the teg.. </TD></TR></TABLE>
i put a thick all aluminum koyo radiator in my teg and the stock fans dropped right in. the fans even cleared my header.
Old Mar 23, 2005 | 06:38 AM
JamaicanDM's Avatar
Default Re: Radiator (timmy8151)
they are $128 with free shipping
Old Mar 23, 2005 | 08:50 AM
95gsrteg's Avatar
Default Re: Radiator (JamaicanDM)
get the oem one, its the best way to go.....there are no problems with fitment.
yes, the manual and auto radiators are different in that they have those cooling fitting lines.
Old Mar 23, 2005 | 09:41 AM
Default Re: Radiator (greaseball)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greaseball &raquo;</TD></TR><TR><TD CLASS="quote">i put a thick all aluminum koyo radiator in my teg and the stock fans dropped right in. the fans even cleared my header. </TD></TR></TABLE>
on my car we would have had have to bend a few lines.. the gap between the fans and the header were smaller than a few sheets of paper... i'm not gonna pull a mickey mouse job on my teg.. might as well do it right the first time around.. keep in mind my teg was still using the stock header and heatshields as this member will probably may or may not be doing..
i also go to hpde's in 100 degree weather.. my koyo oem replacement holds up just fine..
Old Mar 23, 2005 | 09:58 AM
greaseball's Avatar
... i'm not gonna pull a mickey mouse job on my teg.. might as well do it right the first time around.. </TD></TR></TABLE>
are you suggesting that because i used the thick koyo, that i "pulled a mickey mouse job"? my car runs cooler than almost any 200whp car. everything fits and nothing is "mickey moused". besides, i highly doubt any "mickey mouse" job would last almost 4 years!
Old Mar 23, 2005 | 10:35 AM
no. i'm not saying u pulled a micky mouse on on your car. i'm sorry you took it that way. i never meant it to be directed at you in any way shape or form..
i know nothing of your setup you know nothing of mine.. don't stay upset over a few words you can prove me wrong if you wish.. post a pic of ur setup so the topic poster can see the clearance between the stock fans and your header.. let him decide..
my engine rocks too much during hpde's.. and i'm not going to chance damaging the fans with the questionable clearance... i wouldnt mind if i had a way to tow my car to and from the track but i don't... at that point in time i wasn't looking to take out the a/c and didn't have the extra dough to cash out on slim fans.. situtations are different for each person in different situations..
i will agree with you that the koyo all aluminum does keep the car cooler than most.. hell i've seen this radiator perform for endurance races..
that's why they call it a discussion forum.. i'm not picking a fight.. there are certain ways i like things setup on my car there are certain things you like on your car.. no one's own personal opinion can ever be wrong..
Old Mar 23, 2005 | 10:52 AM
greaseball's Avatar
yeah i took it wrong. but the funny thing is man, we have the same exact car! your's being a '98 and mine being a '99. same color and everything. my car is a daily driver and has seen the track as well as quite a bit of nitrous, quite frequently. the koyo i installed uses all factory mounting hardware. it was a direct bolt in! there is not much clearance between the fans and the header, but i've never had any problems.
Modified by greaseball at 10:08 PM 3/23/2005
Old Mar 23, 2005 | 10:59 AM
Is it an OEM replacement all aluminum? If it is and it fits just as you say it does - that would be a good way to go to keep it cool.. Do you mind me asking where you got it and if you installed it yourself (if you did was there any problems)
And is it worth it going koyo?.. i live in central florida and i'd like to keep my car as cool as possible.. any help would be appreciated
Old Mar 23, 2005 | 11:16 AM
jDMJeRk's Avatar
I would bring in a few suggestions to your replacement plan:
If you were going to go turbo, Id buy a half size radiator now. If your just need to replace it buy one that offers a lifetime warranty. You cant go wrong there!
Old Mar 23, 2005 | 01:07 PM
greaseball's Avatar
Is it an OEM replacement all aluminum? If it is and it fits just as you say it does - that would be a good way to go to keep it cool.. Do you mind me asking where you got it and if you installed it yourself (if you did was there any problems)</TD></TR></TABLE>
no, it was not the OEM one. it is the 2" thick one. looks just like the fluidine one. i did install it myself and it was pretty damn easy. i purchased it 3 years ago from XS Engineering. it was pretty damn pricy...$430.00.
Old Mar 23, 2005 | 05:15 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Just get a OEM style replacement from: http://radiatorbarn.com . They're about $100 shipped and have a lifetime warranty. I've been running one of these radiators for about 80K miles without any problems.</TD></TR></TABLE>
Ditto
You can also upgrade to a metal rad for $25 more
1996hondaaccord
Aug 11, 2008 03:11 PM
GSblueRacing
May 28, 2005 09:26 PM
vgsr
Apr 8, 2005 09:16 PM
vtec_outlaw
Dec 2, 2001 08:49 PM
joeg26er
Nov 1, 2001 04:59 AM
