HOW TO SET TIMING
Old Mar 18, 2005 | 07:40 PM
josephcrowe's Avatar
Default HOW TO SET TIMING
THIS IS MY FIRST TIME. I JUST PUT A ZC MOTOR IN MY 89 INTEGRA IM TRYING TO FIND OUT HOW TO SET IT A TDC AND SET THE TIMING PLEASE HELP
Old Mar 18, 2005 | 07:59 PM
natesgarage's Avatar
Default Re: HOW TO SET TIMING (josephcrowe)
The plastic on the side of the motor that has the bas needs to be removed. Then you rotate the cam until the notch is on top then you rotate the crank until the notch on the crank matches the line, slide belt on, and your done. Also if you search you can get more details.
raverx3m
Apr 9, 2012 09:15 AM
MrCivic
Mar 4, 2008 07:21 PM
1990si
Aug 7, 2006 12:34 PM
Keri's_baby
Dec 23, 2005 04:24 PM
nfinitecc
21
Nov 28, 2004 02:22 PM
