maintenance light
Old Mar 21, 2005 | 08:48 AM
hooddub's Avatar
Default maintenance light
00 gsr < when i start the car it blinks 10 times, is this normal or should i have it checked out?
Old Mar 21, 2005 | 08:52 AM
sleeper96's Avatar
Default Re: maintenance light (hooddub)
it's normal,just letting you know your due for a schedual maintence.soon it will stay on and just needs to be reset.The button is under the right side of the dash.
Old Mar 21, 2005 | 08:53 AM
uzabatty's Avatar
might just be the 8k reminder
Old Mar 21, 2005 | 09:11 AM
hooddub's Avatar
its got 33k on it now. it doesnt stay on it just blinks 10 times at start up. dunno?
Old Mar 21, 2005 | 09:22 AM
MugenGSR2001's Avatar
Default Re: (hooddub)
Its a reminder light to let you know you should go in and get your car serviced. Its programmed into the ECU (I believe) at regular mile intervals to let you know you need to get your car serviced. After a while, if you ignore the blinking light, it will just stay on as a constant reminder.
There is small button under your steering wheel dash that can be pressed and held that turns the blinking light off.
Old Mar 21, 2005 | 09:23 AM
dod's Avatar
dod
it will eventually stay on , you just need to press the button under the dash, with the car off and the key on.
Old Mar 21, 2005 | 09:46 AM
hooddub's Avatar
how often does it do this , it already came on at 23k or 25k i cant remember and i reset it. just dont know if its supposed to do this everytime i need an oil change or what.
Old Mar 21, 2005 | 09:52 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooddub &raquo;</TD></TR><TR><TD CLASS="quote">how often does it do this , it already came on at 23k or 25k i cant remember and i reset it. just dont know if its supposed to do this everytime i need an oil change or what. </TD></TR></TABLE>
The light comes on at 7500 mile intervals between resets. It's just a dummy light and doesn't mean that there is anything wrong.
Old Mar 21, 2005 | 11:44 AM
5 Speed AP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooddub &raquo;</TD></TR><TR><TD CLASS="quote">its got 33k on it now.</TD></TR></TABLE>
Aww. Its still a baby.
Old Mar 22, 2005 | 09:05 PM
hooddub's Avatar
unplugged..
Old Mar 22, 2005 | 10:46 PM
Tampa94lsteg's Avatar
just press and hold the button under the right side of your steering wheel....
whatsausername
Honda Civic (2006 - 2015)
Jun 16, 2009 02:55 PM
So FReSh
Oct 9, 2008 12:29 PM
civic5483
Jan 19, 2007 05:18 PM
b20acura
Nov 24, 2005 09:44 PM
NeoGSR
Sep 11, 2002 07:22 AM
