Engine won't start
Old Nov 16, 2012 | 10:09 PM
Johnoolo's Avatar
Default Engine won't start
I was driving down the highway and all of the sudden my 2001 Acura Integra cut off I have power the car will turn over but not crank I was driving and then just no engine no Indication at all
Old Nov 17, 2012 | 01:53 PM
NUISANCE's Avatar
Default Re: Engine won't start
Kinda vague, any codes? What have you ruled out/tried so far?
Old Nov 17, 2012 | 02:10 PM
el crapitan's Avatar
just want to be clear here, the engine does crnk but will not fire, yes? if so, pull the oil fill cap. with someone cranking, check to see if the cams are turning through the oil fill hole.
if they are, CHECK for codes.
if no codes, check the usual suspects:
ignition
fuel
timing
compression
Old Nov 19, 2012 | 06:49 AM
Johnoolo's Avatar
I deduced it was the timing belt so my parents sent it to the shop because that is a hard fix.
klh2000
Honda CR-V & Element
Nov 22, 2020 04:08 AM
hotdeli
Jul 29, 2008 07:58 PM
gq420j
Jun 12, 2008 10:55 PM
Paluce
Mar 21, 2007 04:30 PM
TURBO
Jul 2, 2004 10:05 AM
