Engine Misfiring?
Old Nov 27, 2012 | 05:49 PM
brendan97's Avatar
Default Engine Misfiring?
The other day the clutch in my 97 teg got really spongy, then eventually lost all return pressure and stayed on the floor. I suspected it was the slave cylinder, since I replaced the master clutch almost a year ago. Its been sitting for two days now and I went out to see if I could drive it without the clutch to the shop I work at, I turned it over and the engine jumped forward and slowly died. I also smelled some smoke.
It was in neutral when this happened and now when I try to start it, it basically does this half *** crank, and seems to be flooded or something. I waited a few min. and tried it again. It started, but ran really weird, almost like it was misfiring in two of the cylinders.
Anybody have any ideas of what this could be?
Old Nov 27, 2012 | 06:33 PM
Hanmin's Avatar
Default Re: Engine Misfiring?
For your clutch, bleed the clutch lines and then drive it.
For the starting, since it lunged forward in such a manner you should just look under the hood and check for loose connections, especially at the distributor. Make sure your grounds are all intact as well.
Old Nov 27, 2012 | 07:49 PM
brendan97's Avatar
I didn't see any loose connections and all the grounds seemed to be connected.. hopefully its just something I overlooked
Old Nov 27, 2012 | 08:44 PM
brendan97's Avatar
So I just went out and tried starting it..it starts, but still doesn't idle like it should. It idles rough and chokes itself out every few seconds. It also smells like gas pretty bad and makes a spitting noise somewhere around the intake.
Old Nov 28, 2012 | 12:42 AM
Hanmin's Avatar
let it warm up and see what happens, does it choke randomly and sputter randomly or does it feel like it is just always running shitty?
Old Nov 28, 2012 | 04:48 AM
fcm's Avatar
fcm
Old Fart
Sounds like you may have an injector stuck open. 94
eman96
Sep 4, 2015 06:31 AM
blacklabel14
Feb 3, 2011 12:32 PM
blacklabel14
Feb 2, 2011 08:48 PM
mr. robot-o
Nov 9, 2008 06:27 AM
ILOVEGIRLS
Mar 10, 2002 08:47 PM
