Is my engine done?
Old Nov 3, 2012 | 07:47 AM
jonyi27's Avatar
Default Is my engine done?
So my uncle mixed up some hose wrong and got coolant in my oil, I left it on idle for like 2 mins and it stayed in the car over night I just drained out all the oil and had some new oil left so I put it in to clean the motor a little from the coolant.... Is my engine done or should I be good with a new oil change?
Old Nov 3, 2012 | 07:54 AM
el crapitan's Avatar
Default Re: Is my engine done?
dump the oil. replace with cheap stuff. idle for 20 minutes and dump again. se how it looks coming out
Old Nov 3, 2012 | 07:59 AM
jonyi27's Avatar
What would I be looking for? If white smoke is coming out?
Old Nov 3, 2012 | 08:06 AM
fcm's Avatar
fcm
Old Fart
Pretty sure el crapitan means what the oil coming out, [when draning] looks like. 94
Old Nov 3, 2012 | 08:17 AM
yes. look closely for shimmer in the oil. drain into a clean pan and shine a flash light at it. also, when idling, listen closely for tell tale signs of bearing failure. like squeaking. if any material came off, it'll show in the initial oil that you drain and the next drain.
since you didn't actually drive it or run it for a long period, you'll probably be alright
Old Nov 3, 2012 | 08:28 AM
jonyi27's Avatar
I look at the oil that was in the pan an I saw like very very very little shimmer like 5 very very very little shimmer... Should I be in a better light?
Old Nov 3, 2012 | 08:33 AM
jonyi27's Avatar
Should I put oil treatment to help it out?
Old Nov 3, 2012 | 08:35 AM
i wouldn't be worried about a couple of flakes. that may just be be debris from something else. what you're really looking for is large amounts of tiny metal particles that give the oil a shimmer
Old Nov 3, 2012 | 08:38 AM
jonyi27's Avatar
You just saved me from a heart attack for now lol thanks ill keep ya updated
Old Nov 3, 2012 | 08:39 AM
no. you want to run it for 20 minutes on the cheapest oil possible. don't even bother changing the filter for this short session. just remove it, dump the oil out of it, and reinstall. you just want to flush it
TBH, i highly doubt it'll have had any immediate effects. maybe MAYBE in the very distant future.
Old Nov 3, 2012 | 09:03 AM
jonyi27's Avatar
What if it shimmers very little tho not a lot at all
Old Nov 3, 2012 | 10:07 AM
well, you really shouldn't have any shimmer at all. by shimmer i mean that the actual content of the oil sparkles. not just a few flakes. all you can do at this point is flush it to get rid of the coolant cross contamination. maybe drive it for a couple hundred miles and dump the oil again to inspect.
Old Nov 3, 2012 | 01:53 PM
ChE_UND_09's Avatar
Maybe drain and flush.
Old Nov 3, 2012 | 05:34 PM
GSR360's Avatar
dump oil
jnb0111
Oct 25, 2015 04:13 PM
mcd7
16
Jun 6, 2011 09:33 PM
Azxster
Jan 8, 2008 04:36 PM
Malakai
Mar 5, 2007 01:23 PM
Bond
20
Nov 2, 2005 03:12 PM
