30+ offset for track use?
Old Oct 28, 2012 | 12:56 PM
tekstyle's Avatar
Default 30+ offset for track use?
https://honda-tech.com/forums/road-racing-autocross-time-attack-19/30-offset-dc2-3099627/
sorry for linking this thread to a one in the road race forum.
I just wanna know if 30+ offset 15x7 will mess up handling characteristics and driveability on the track? they stick out about 10mm from the fender.
i already know that wheel bearing and knuckles will have more stress and also require stiffer suspension.
Old Oct 28, 2012 | 03:11 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: 30+ offset for track use?
Should help with the wider stance in the corners. I dont see how a 15x7 +30 sticks out from the fenders by 10mm. What vehicle??? +30 is so close to OEM (+40 to +36)offsets that you shouldn't have to worry about added stress on bearings and knuckles. IMO
Old Oct 28, 2012 | 03:21 PM
1998GsRIntegra's Avatar
Short answer nope...long answer nope.
Old Oct 28, 2012 | 04:57 PM
tekstyle's Avatar
these are the 30+ but they stick out a little. tires are 195/50/15R
Old Oct 28, 2012 | 06:00 PM
You are not going to have any problems unless the tire doesn't tuck into the fender going around a corner. You may need to run more negative camber if that becomes an issue. Trust me you will be fine. I wish I had pictures of some of the stuff I've seen before. Just imagine 235/40-17 on a 17x8 wheel on your car. I've done it before and I know plenty of people running the same setup on their racecars. No issues.
95_GSR_SEDAN
20
Jan 8, 2012 07:43 PM
Root of all Evil
Sep 6, 2011 08:05 PM
yusoslo
Aug 20, 2003 01:27 PM
nd8ch
May 12, 2003 10:47 AM
XR4racer
Jul 19, 2002 05:17 PM
