question about power conversion
Old Nov 28, 2012 | 12:01 AM
kwijibodavid's Avatar
Default question about power conversion
ok im using a 96 intergra harness to do my power window conversion in my hatch and ima repost my question here
ok so i just finished taking apart a 96 integra 2dr harness and there was 4 extra wires leaving the passanger side harness i beleve that they were prewired for a 4 door. so that the passenger lock switch could lock the rear doors can anyone confirm that these are what there for .
the colors are blk/red, light blue, blk/wht, and light green
Old Nov 28, 2012 | 05:16 AM
fcm's Avatar
fcm
Old Fart
Default Re: question about power conversion
All door lock wiring from all doors run to the "Power Door Lock Control Unit" the leads from the key cylinders, [drivers and pass. doors] run to the PDLCU and are for Central Locking, [using a key in either door to lock or unlock will lock or unlock all doors] the only wire that is common between any of the doors is the black ground lead.
Front pass. door key cylinder switch wiring are...
Blue/white @ cylinder, changing to light blue - lock
Blue/red @ cylinder, changing to light green - unlock
Black - ground
Front pass. door lock switch..
Black/white - lock
Black/red - unlock
Black - ground
Front pass. door lock actuator..
White/red
Yellow/red
Both of the above lock and unlock leads and the actuator leads run to the PDLCU, the black ground leads are chassis grounded inside pass. compartment, [not in the door].
Other leads running into the pass. door will be speaker leads, from radio...
Red/green Sp. pos(+)
Brown/black Sp. neg(-)
There will also be leads for the power mirror, from drivers door, sorry no wire colors for them. 94
Fatdicklegend
Oct 15, 2015 07:36 PM
vartok
Mar 14, 2014 07:55 PM
Thateguhate
Feb 21, 2009 08:08 AM
veggiemaster
Audio / Security / Video
Jun 9, 2005 10:13 AM
eddie1681
16
Sep 24, 2004 11:14 PM
