Stroke on a b18c
Old Dec 10, 2006 | 08:37 PM
Del Sol on Steroids's Avatar
Default Stroke on a b18c
whats the longest stroke that i can take on a b18c block? or will it be easy to get the stuff i need if I go with a dart long block?
Old Dec 10, 2006 | 08:48 PM
doood's Avatar
been there done that
Default Re: Stroke on a b18c (Del Sol on Steroids)
95mm
Old Dec 10, 2006 | 09:00 PM
lqd44's Avatar
Default Re: Stroke on a b18c (that one doood)
im sry if this sounds dumb and all, i mean i understand what bore and stroke is, but how do u make the stroke longer? is it possible, or are u just asking something totally different..
Old Dec 10, 2006 | 10:39 PM
99Geeezer's Avatar
Default Re: Stroke on a b18c (lqd44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lqd44 &raquo;</TD></TR><TR><TD CLASS="quote">im sry if this sounds dumb and all, i mean i understand what bore and stroke is, but how do u make the stroke longer? is it possible, or are u just asking something totally different.. </TD></TR></TABLE>
larger crankshaft stoke=more displacement
Old Dec 10, 2006 | 10:45 PM
davidluko's Avatar
Yea get a "wider" crankshaft so that the bottom of the rod moves farther out to the sides. It'll increase displacement and make the piston move down farther, and increase torque, but a negative is that it'll put more stress on the sidewalls.
Old Dec 11, 2006 | 10:14 AM
so what is the max that i can go on a b18c?
Old Dec 11, 2006 | 01:03 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids &raquo;</TD></TR><TR><TD CLASS="quote">so what is the max that i can go on a b18c?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">95mm</TD></TR></TABLE>
you can probably go bigger but that would require even more custom work
Old Dec 11, 2006 | 01:56 PM
with 95 I'm good, good looking out. I really needed this info.
Old Dec 11, 2006 | 02:03 PM
Boots's Avatar
Default Re: (Hatch_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">Yea get a "wider" crankshaft so that the bottom of the rod moves farther out to the sides. It'll increase displacement and make the piston move down farther, and increase torque, but a negative is that it'll put more stress on the sidewalls.</TD></TR></TABLE>
could always sleeve it
Old Dec 11, 2006 | 04:18 PM
doood's Avatar
Default Re: (boots)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">could always sleeve it</TD></TR></TABLE>
you can only get so much displacement by sleeving and overboring. throw in a big stroke and you've got yourself a 2.1-2.2L
Old Dec 11, 2006 | 04:34 PM
Default Re: (that one doood)
I was thinking of brian crower, it comes with a 95 crank. other then spoon, scat and toda, are they anyother?
Old Dec 11, 2006 | 08:18 PM
Muckman's Avatar
Moderator in Chief
Default Re: (Del Sol on Steroids)
eagle
Old Dec 11, 2006 | 08:21 PM
JDMorgan's Avatar
95mm is pretty normal and completely safe on a b18. if you go dart tall block, i heard of people running 105mm stroke.
Old Dec 11, 2006 | 08:49 PM
Muckman's Avatar
Moderator in Chief
Default Re: (JDMorgan)
Who makes a 105mm crank?
Old Dec 11, 2006 | 08:52 PM
lqd44's Avatar
so is it better increasing the bore, or the stroke?
Old Dec 11, 2006 | 09:05 PM
JDMorgan's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Who makes a 105mm crank?</TD></TR></TABLE> custom order.
im running a crower 95x81 kit now and it is pretty sweet, im almost tempted to sleeve my block and go 95x84.
Old Dec 12, 2006 | 04:59 AM
Boots's Avatar
Default Re: (lqd44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lqd44 &raquo;</TD></TR><TR><TD CLASS="quote">so is it better increasing the bore, or the stroke?</TD></TR></TABLE>
depends...but usually they go hand in hand
Old Dec 12, 2006 | 05:29 AM
Muckman's Avatar
Moderator in Chief
Default Re: (lqd44)
If you want to get technical, increasing bore doesnt affect R/S ratio.
Old Dec 12, 2006 | 07:44 AM
doood's Avatar
Default Re: (lqd44)
boring to 85mm puts you at ~2L without messing with the revvability of the engine
Old Dec 12, 2006 | 09:02 AM
JDMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">boring to 85mm puts you at ~2L without messing with the revvability of the engine</TD></TR></TABLE>AS MUCH.
Old Dec 12, 2006 | 09:16 AM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMorgan &raquo;</TD></TR><TR><TD CLASS="quote">AS MUCH.</TD></TR></TABLE>
plus one...You decrease the wall thickness youre definately playing around with its revvability
Old Dec 12, 2006 | 12:58 PM
davidluko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">If you want to get technical, increasing bore doesnt affect R/S ratio.</TD></TR></TABLE>
Nobody said it did. Increasing stroke does. But with increasing the bore, you have to worry about too thin of sleeves.
Old Dec 12, 2006 | 04:36 PM
lqd44's Avatar
so when u increase the stroke, ur max rpm drops?
Old Dec 12, 2006 | 04:56 PM
davidluko's Avatar
It doesn't necessarily drop until you go past a point where it would start cracking sleeves. I'm not an engine builder or anything so I couldn't say what that point is, but that's the jist of it.
Old Dec 14, 2006 | 05:09 PM
what about the bore is 87 too much, should I stick with 84?
