transmission problem
Old Dec 11, 2006 | 01:08 PM
crispchris's Avatar
Default transmission problem
hey you guys, a few days ago my transmission started not wanting to go into gear, when the car
is in neutral it sometimes wants to roll forward like an automatic would if i don't have my foot on
the break, and if it is shifted in reverse with my foot all the way down on the clutch it will want to
roll backwards even on a completely flat surface.... i have already had my transmission fluid
changed which seemed to help a little bit... the car also has a stage 3 clutchmasters clutch in it
and an exedy light weight flywheel in it which i thought might be the cause but the car has ran
smoothly for about 6000 miles with it, if you have any thoughts i would gladly appreciate it
Old Dec 11, 2006 | 01:39 PM
95 integra's Avatar
Default Re: transmission problem (crispchris)
Clutch adjustment and/or your clutch system is beginning to fail. Check the reservior and see if it still has plenty of fluid. Also, the car rolls forward even in neutral or with the car in 1st and the clutch pushed in?
Old Dec 11, 2006 | 06:14 PM
crispchris's Avatar
Default Re: transmission problem (95 integra)
it was rolling while in neutral and the pedal seemed to be sticking a bit, it seemed
as though the place didn't fill up the tranny fluid like they should have, because
this afternoon after puttin some more in and pumping the pedal a little bit it
seemed fine... will see i'll keep you guys updated if the problem shows up again,
thank you very much for the help
keiserbikes
Transmission & Drivetrain
Nov 19, 2012 07:26 AM
ramz7887
Oct 16, 2008 12:33 PM
onyx00
Dec 11, 2004 02:56 PM
just4747
28
Dec 5, 2004 11:30 AM
swpdb16
Nov 18, 2002 11:25 AM
