snaping axles?2x autozone ones just in one day
man driving on 5 at 70 i boosted in 4th and boom car feels like the wheel feel off
almost hit a dam truck and the wall!!@#@
then at willow springs lateron on a stright i was trying to pass up the car.. boosted in 4th again
boom same ****!#@$!
wth can it bE?
i boosted all gears draging fine but it just seems like its ******* up this week soo bad...
car feels loose now
any tips
currently in socal>trying to fix as much as i can
boom same ****!#@$!
wth can it bE?
car feels loose now
any tips
get higher quality axles like stage 2 or something how many lbs are you pushing? its retarded to boost a lot and use stock axles.. maybe your suspension is loose somewhere check it all out all the bolts and stuff
Re: (importdude2000)
possibly your differential...did the axle bust at the wheel or near the half shaft/ transaxle?
If not maybe your neg. camber is to blame.
Hype-R Stalker
Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Ive also broken 2 autozone axles in the same day. 1 broke after 100 feet of driving a 90hp civic.</TD></TR></TABLE>
Yeah .. But what kind of torque were you making??
Making 200+ hp, I would just get aftermarket/Stronger axles for the peace of mind.
Re: snaping axles?2x autozone ones just in one day (importdude2000)
check ur motor and trans mounts,If the engine doesnt sit right it puts the axles in a bind..my couisin broke 2 in the same side..found broken top trans mount after replacing it he has mo more problem......
ive had to go thorugh 2-3 sets before i finally got one tht ddnt make noises when turning.. they suck ***** but u get unlimited amount hahaha.. juss waste of time / labor.
Re: snaping axles?2x autozone ones just in one day (JDM As It Gets)
something isn't right here.....
The chances of both axles going is slim to none. Sure it's not the diff?
Deff check the mounts the same **** happened to me lol!
The 3 bolts on the driverside mount were broken in the block and allowed the engine to sag..
Kept breakin the axles 10 minutes apart from eachother haha!
Re: (DatDBisNaSty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DatDBisNaSty »</TD></TR><TR><TD CLASS="quote">Deff check the mounts the same **** happened to me lol!
Kept breakin the axles 10 minutes apart from eachother haha!</TD></TR></TABLE>
thats some scary ****!
1 Post
Re: (DatDBisNaSty)
I have to say, this had to have been one of the most frightening situations I've been in, with my db. Traveling on the freeway, about 1:50 am, I decided to just be an idiot and see what my car could do. Slam the gas, accelerating nice and quickly....just passing the 130mph mark on my spedometer, my wheel jerks hard to the left. I counter steer, drop the car out of gear, and wonder WTF happened. I get back into gear, try to accelerate, but cant. RPM's are rising, but no acceleration. I have to get towed home at that point,
Following morning, I throw my car on jack stands, and this is what I see...
http://img.photobucket.com/alb...a.jpg
http://img.photobucket.com/alb...d.jpg
http://img.photobucket.com/alb...y.jpg
And I just got that axle 3 days ago...No more than 50 miles on the car since replacement. AutoZone Remans...
Re: (EnjoyTheRideDC2)
For $10 more than the remans, you can buy New GCK axles at Autozone and Advance auto parts. Mine were $70 at Advance/Discount auto.
for 90-93 Integras
left ho8057A
right ho8056A
And here is a thread about someone using them at the track and running them for 2 years before his high whp turbo setup finally snapped one using slicks at the starting line.
https://honda-tech.com/zerothread?id=835809
for 90-93 Integras
left ho8057A
right ho8056A
1 Post
Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">For $10 more than the remans, you can buy New GCK axles at Autozone and Advance auto parts. Mine were $70 at Advance/Discount auto.
for 90-93 Integras
left ho8057A
right ho8056A
https://honda-tech.com/zerothread?id=835809</TD></TR></TABLE>
Yeap, I found that out later...about 2 axle swaps later. I'm just saving up for a set of Raxles or maybe a set of EMPI's..
for 90-93 Integras
left ho8057A
right ho8056A
Oreo-TeCk
07-01-2007 10:33 PM
92gsrteg
04-13-2006 05:48 PM
