LS Budget Performance
Old Dec 8, 2006 | 07:26 PM
RS'R''s Avatar
Default LS Budget Performance
I've got a 94 Integra RS and its bone stock.
What have people done for $800?
I was thinking...
For suspension: (used) GC coil-overs w/Koni Reds? Then some lighter wheels.
Reliability upgrades: AEM V2 intake, DCSports Header.
Thankful for all suggestions!
Old Dec 8, 2006 | 07:43 PM
PrinceAli132's Avatar
Default Re: LS Budget Performance (whitewizard)
Track time
Suspension
Brakes
Tires (Rims as well if you can afford it)
Ali
Old Dec 9, 2006 | 01:16 AM
DC4 me's Avatar
Default Re: LS Budget Performance (PrinceAli132)
i installed crower 402's on my ls. cheapest upgrade you can do that'll give u the most gains. forget about the v2, its a load of crap, ive done all the bolt ons on my ls, and the best gains i got were from the crower cams.
Old Dec 9, 2006 | 01:17 AM
DC4 me's Avatar
Default Re: LS Budget Performance (lghnea)
also with the 402's, you dont need the titanium retainers and valve springs which cost as much as the cams do.
Im selling my 402's by the way. Im getting a gsr swap in a few weeks. If you want to buy my cams, ill sell them to you for cheap.
Old Dec 9, 2006 | 01:19 AM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lghnea &raquo;</TD></TR><TR><TD CLASS="quote">also with the 402's, you dont need the titanium retainers and valve springs which cost as much as the cams do.
Im selling my 402's by the way. Im getting a gsr swap in a few weeks. If you want to buy my cams, ill sell them to you for cheap.</TD></TR></TABLE>
yo how much for the cams
Old Dec 9, 2006 | 01:39 AM
bg-33p's Avatar
Default Re: LS Budget Performance (jdmboi86)
You mean Koni yellows? The koni yellow + gc coilover setup will run you a good 400+, wheels about 300, and an intake for about 100. You're set.
Old Dec 9, 2006 | 01:45 AM
DC4 me's Avatar
Default Re: LS Budget Performance (teggysue)
i bought my cams for 350 plus tax n shipping from crower. Ill sell you my the cams for 250. Ill be taking them out in a week, itll be ready to ship by then if you want them. They have only been used for 2000 miles. very new, im sad i didnt get to use them longer.
Old Dec 9, 2006 | 01:47 AM
DC4 me's Avatar
if you want to use those cams, i recommend using cam gears, i had mine set at +1,-1... It made good gains all throughout the power band, but more noticeable on the upper portion of the power band, especially cuz i had these on an ls. Best part is, no need for springs/retainers. You can simply just drop these in and youre good to go.
Modified by lghnea at 3:16 AM 12/9/2006
Old Dec 9, 2006 | 02:35 AM
alexisthemovie's Avatar
koni yellow shocks, ground control coilovers, type r rear sway bar, and track time.
Modified by alexisthemovie at 10:14 AM 12/9/2006
Old Dec 9, 2006 | 02:40 AM
Fat Chick Magnet's Avatar
koni yellows w/ groundcontrols
you can also look into getting ASR brace w/ 22mm itr rear sway bar.
Old Dec 9, 2006 | 03:57 AM
SYNSEI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue &raquo;</TD></TR><TR><TD CLASS="quote">You mean Koni yellows? The koni yellow + gc coilover setup will run you a good 400+</TD></TR></TABLE>
Huh? Thats a $700+ setup.
Old Dec 9, 2006 | 04:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYNSEI &raquo;</TD></TR><TR><TD CLASS="quote">Huh? Thats a $700+ setup.</TD></TR></TABLE>
Probably more like a 825 setup. Koni's are roughly 500 shipped (every now and then someone sells them for a little less) and Ground Control Coilovers are around 325 shipped.
Even if you had $825, its not enough. Are you going to be installing this yourself, or paying someone? Also, a lot of the times, there is a seized bolt or bushing (usually one on the rear lower control arm) that might need replacing. And you also need to get an alignment afterwards. Some people also decide to get a camber kit for the front as well.
Ali
Old Dec 9, 2006 | 05:23 AM
RS'R''s Avatar
Thanks for the advice.
I'll be doing all the work myself... If I can't do it, someone local from HT can help me.
Ye, I meant Koni Yellows. I heard they are great. Sadly, new theyre not in my price range. I still want a good setup for autox in the spring.
Should I be buying everything new?
Crowers sound great, I just don't want to be doing internals on a 157k engine.
Modified by whitewizard at 6:58 AM 12/9/2006
Old Dec 9, 2006 | 06:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitewizard &raquo;</TD></TR><TR><TD CLASS="quote">I still want a good setup for autox in the spring.</TD></TR></TABLE>
Honestly, you should go out and auto-x, stock. Learn you car first and its limits. Also, when upgrading your car it will probably change your classing. Therefore, probably making you less competitive.
Ali
Old Dec 9, 2006 | 06:35 AM
97itypeR's Avatar
with 800 i wouldnt touch my motor..
id use the $800 and buy things to put towards the handling of the car.
sway bar, strut bars, pillar bar, coil overs, shocks etc.
Old Dec 9, 2006 | 08:00 AM
RS'R''s Avatar
fair enough. intake for now... ill wait to do any serious suspension or engine mods until i really get to know the car.
cant wait to get out in the snow for some mad driftin yO!
thanks for good advice!
Old Dec 9, 2006 | 11:58 AM
bg-33p's Avatar
Default Re: (whitewizard)
For used i've seen it personally go for around 450-500. I've been looking for the best prices and trust me i've seen new koni yellows go for 400 and gc coilovers for 200 new. So it's definitely not 700+ but maybe around there.
Old Dec 9, 2006 | 12:05 PM
dohcMONSTER's Avatar
best bang for your buck is a b16 tranny, shorter gearing is your best friend. And will net you better gains than any bolt ons
Old Dec 9, 2006 | 12:47 PM
sneakysneaky's Avatar
Id buy a spare motor for $100 out of local paper and as much gas as u can get or
a small turbo setup
Old Dec 9, 2006 | 01:45 PM
RS'R''s Avatar
Default Re: LS Budget Performance (sneakysneaky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakysneaky &raquo;</TD></TR><TR><TD CLASS="quote">Id buy a spare motor for $100 out of local paper and as much gas as u can get or a small turbo setup </TD></TR></TABLE>
as much gas as i can get right
ye, ls blocks are def cheap (ive seem some go $100) and going ls/vtec is always an option. maybe ill buy a block now, buy a b16 head... build the motor in my basement and put it in when its all ready. just an idea... ive heard they can be unreliable and tuning can be a problem as it isnt a factory engine.
Old Dec 9, 2006 | 04:58 PM
97CGPintegra's Avatar
Default Re: LS Budget Performance (dohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">best bang for your buck is a b16 tranny, shorter gearing is your best friend. And will net you better gains than any bolt ons</TD></TR></TABLE>
^^^this is it's worth the money if you want to go faster, want to stay all motor and only have $800.
at the end it depends on what you want to do with the car. if i had a ls, i would get either the b16 tranny or a nice suspension set-up. depends on what kind of used deals i could find.
spuddo01
Jan 13, 2007 07:54 PM
hondatuner20
Jun 7, 2005 01:52 PM
dohced
Feb 9, 2005 08:45 AM
cxVtecC1
Nov 14, 2004 07:28 PM
