grinding third please please help
Old Dec 7, 2006 | 08:24 PM
cubanteg16's Avatar
Default grinding third please please help
so i have a 94 gsr and when the car is warm after driving it a bit it grinds every time in 3rd also when its high reved i have to get out of 2nd and wait till the rpm hits around 3 so it will go in smooth does anyone noe wut could be my problem thanx
Old Dec 7, 2006 | 08:31 PM
87shytwhip's Avatar
Default Re: grinding third please please help (cubanteg16)
simply your trans is fked.. you need to replace the gear.. beating on your honda has a tendency to cause 3rd to mess up first.. its kinda common actually
Old Dec 7, 2006 | 10:07 PM
99Geeezer's Avatar
Default Re: grinding third please please help (87shytwhip)
Could be sychros. possibly the gear. a rebuild might be in your forcast.
Old Dec 8, 2006 | 05:27 AM
LoseRPunKx182's Avatar
Default Re: grinding third please please help (99Geeezer)
maintance like refilling the transmission with fluid helps
Old Dec 8, 2006 | 06:02 AM
lVlemphizStylez's Avatar
Default Re: grinding third please please help (LoseRPunKx182)
replace it asap..it will lead to other problems in the transmission...mainly more costly ones
Old Dec 8, 2006 | 07:05 AM
92gsrteg's Avatar
i had a bad 3rd and 4th grind and then when i had a new clutch put in, the shop owner changed the tranny oil and its only grided once since, tranny's a 92 cable ls with a turbo jdm gsr. runs good now. try changin the oil with somethin good.
Old Dec 8, 2006 | 07:26 AM
mtny's Avatar
Default Re: grinding third please please help (92gsrteg)
Change your tranny fluid with GM synchromesh. I had some grinding in my EM1 but and it eliminated it.
Old Dec 8, 2006 | 11:05 AM
hondaddy316's Avatar
syncros
Old Dec 8, 2006 | 11:07 AM
cubanteg16's Avatar
you noe i did just drained my tranny oil and added new oil and it still does it so does this mean my gear is just fucked up
Old Dec 8, 2006 | 11:08 AM
cubanteg16's Avatar
Default Re: grinding third please please help (hondaddy316)
how much u think is the synchos to rebuild or wutever
Old Dec 8, 2006 | 11:43 AM
Mario_D's Avatar
Default Re: grinding third please please help (mtny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">Change your tranny fluid with GM synchromesh. I had some grinding in my EM1 but and it eliminated it. </TD></TR></TABLE>
It wasn't eliminated. It was covered. Changing fluids are band aid repairs at best. You will have to check to see if your synchro, sleeve, or gear have been damaged.
I can not comment on cost as I do my own work. The parts are not expensive.
m-
Old Dec 8, 2006 | 07:33 PM
Oreo-TeCk's Avatar
Default Re: grinding third please please help (Mario_D)
bump
Old Dec 8, 2006 | 07:44 PM
F20Cteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87shytwhip &raquo;</TD></TR><TR><TD CLASS="quote">simply your trans is fked.. you need to replace the gear.. beating on your honda has a tendency to cause 3rd to mess up first.. its kinda common actually</TD></TR></TABLE>
Don't be a moron. The gears are fine.
The synchro for 3rd gear is worn out and is not able to do it's job.
You should have the trans rebuilt so that you don't mess up the dog teeth on the gears.
Contact gear-speed, they do good work.
SIMATIC
May 4, 2011 04:58 AM
EGk3nrock
79
Dec 10, 2007 12:49 PM
Luchini
Dec 4, 2006 10:04 PM
ixcryxblood
Oct 3, 2004 01:42 PM
TIRENECK
Dec 8, 2003 09:47 AM
