Rumbling noise from drivers side
Hi all,
im new to honda-tech.. I have a 2000 ls, when i turn right you can hear a rumbling noise from the drivers side tire. Could it be a wheel bearing?
Re: Rumbling noise from drivers side (pghz_last_don)
a wheel bearing will make a high pitch squeel, and is usuially there all the time while the wheel is turning. Could you better describe the "rumbling" noise?
Re: Rumbling noise from drivers side (JDM_DC4_Fanatic)
I only hear it when im turnin the wheel right. its kinda like virbrating noise, i know i need new rotors, just havent got around to changing them, could that be what im hearing?
it could be rotors ONLY if it makes a noise when you hit the brakes. A wheel bearing wouldent vibrate, unless its soo bad its about to fall out. My guess is ball joint. when you turn, there is extra stress put on them.
Blastek
10-18-2004 08:34 AM
