Skunk2 SS install problem...help...
Old May 7, 2007 | 10:30 PM
integra racr04's Avatar
Default Skunk2 SS install problem...help...
just installed my Skunk2 dual bend on my DC4, and now its hard to get into gear, and i have to force it in. i put the hardware that came with it on how i figured it should go. what could be the problem???
BTW... theres no rattle, or any noise that im hearing, so im pretty sure its not hitting the exhaust.
Old May 7, 2007 | 10:49 PM
BlueIntegraBoy's Avatar
Default Re: Skunk2 SS install problem...help... (integra racr04)
Did you grease the ball part of the shifter with lithium grease?
Old May 8, 2007 | 04:44 AM
stuie08's Avatar
and use the rubber bushings? and grease those?
Old May 8, 2007 | 06:20 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (stuie08)
Your linkage might be binding somewhere too. Check and make sure everything is down tight and in the right place.
Old May 8, 2007 | 07:49 AM
Default Re: (ek forever guy)
thx for all the info guys. no i dint greese anything, i dint know i was supposed to. unfortunately i wont have any time to look at it until the weekend... hopefully its nothing too serious...
Old May 8, 2007 | 09:38 AM
Sam92Teg's Avatar
Default Re: (integra racr04)
If you overtighten the thru-bolt on the bottom of the shifter, it can be hard to shift.
And you could have someone go thru the gears as you watch the bottom of the shifter to make sure there are no clearance issues.
MidnightB16
Mar 27, 2009 12:50 AM
yaoming315
Jun 7, 2007 05:29 AM
AMG
Nov 1, 2004 01:35 PM
