Engine bloging
Old May 8, 2007 | 10:24 PM
maomaniarocks's Avatar
Default Engine bloging
hi i have a 97 gsr and i am having problems. when i take off on 1st gear the engine makes a blogging noise. Say when im going 30mph on 3th gear, and when i step on the gas pendal more it also makes that noise. At first i thought it was running to rich but its not. fuel pressure is good. new o2 sensors. no check engine. need help. if i cant fix must sell.
Old May 9, 2007 | 12:11 AM
clem kevin's Avatar
blogging like posting on livejournal?
Old May 9, 2007 | 09:00 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Engine bloging (maomaniarocks)
Is this just a noise or is there a performance loss as well? What intake are you running? Your 97 should be OBD2 unless the ECU was changed, are there any CELs? If so, look at the Integra FAQ thread for instructions on how to pull them.
Old May 9, 2007 | 10:36 AM
Sam92Teg's Avatar
Could be a weak spark. Check all your ignition components, plugs, wires, cap, rotor. Also check your ignition timing.
Arakami
Jun 19, 2011 08:58 PM
VtecTypeR86
Aug 6, 2004 05:38 AM
Littleredsi
14
Dec 13, 2003 10:32 AM
sleeping_forest
Jun 13, 2003 09:41 PM
