changed oil
Old May 8, 2007 | 02:33 PM
crazytalk's Avatar
Default changed oil
ok this is the first time i do it and i put in the oil and bolt and filter now i turned on my car it worked and then i was hearing a clicking noise and then it stopped then i checked my dipstick and it was barely on the first dot did i put little oil i put in 5 quarts
Old May 8, 2007 | 02:44 PM
berb_15's Avatar
Default Re: changed oil (crazytalk)
you actually only need 4 quarts, I'm not sure why it wouldnt be full enough if you put your drain plug and oil filter on
Old May 8, 2007 | 03:00 PM
Agent_EM1's Avatar
Default Re: changed oil (berb_15)
Wierd man... Double check the filter and the bolt for draining the oil. I was kinda worried about putting too much oil in as well. I put 4 quarts in my Dad's Integra but put 5 in my RSX... Hmmm
Old May 8, 2007 | 03:44 PM
Sam92Teg's Avatar
You have to give the oil time to get down into the pan befor checking the dipstick.
If 5 quarts read low, then you either have the wrong dipstick, an oversized pan, your car isn't on level ground, your misreading the dipstick, or you didn't give enough time for the oil to reach the pan.
Either way, 5 quarts is too much, unless you have a turbo your not telling us about or an oversized pan. Just curious as to why you would put that much in?
Old May 8, 2007 | 03:52 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: changed oil (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">
Either way, 5 quarts is too much, unless you have a turbo your not telling us about or an oversized pan. Just curious as to why you would put that much in?</TD></TR></TABLE>
Because they had this genius idea of making those nifty 5quart containers now..
It might be a good idea, if they actually had a readout on the side of the thing.
Least that's how it is with the Castrol GTX chit.
Old May 8, 2007 | 04:38 PM
crazytalk's Avatar
Default Re: changed oil (CleanLikeJdm)
i know im going to get bagged for this but the oil was clear and clean and its at the appropiate place
4tika4
Aug 8, 2012 09:12 PM
Vtec-Mini
Nov 26, 2011 04:23 PM
rayzian
16
Aug 17, 2007 06:48 AM
tilhasbb
17
Aug 13, 2007 08:17 AM
Tofurky
Jul 9, 2002 10:15 PM
