integra buring coolant?
Old May 7, 2007 | 10:26 AM
integranewb's Avatar
Default integra buring coolant?
I bought the car used, it was excellent.
however just recently ,my car was almost overheated...
there was no more coolant.
i waited 4-5 hours and replaced it with new coolant.
what could have happened? is it possible that it just used up or could it be a problem
after i filled it up the car runs fine and this problem never occurred again.
thanks in advance for any ideas
Old May 7, 2007 | 10:51 AM
VTECth1s's Avatar
Default Re: integra buring coolant? (integranewb)
check your coolant hoses for any leaks, how often are you checking the coolant level? cause it may have dropped again if you just added more coolant if theres a leak.
Old May 7, 2007 | 12:28 PM
BoltonGSR's Avatar
Default Re: integra buring coolant? (VTECth1s)
Possible head gasket... Not specific enough in your post.
Old May 7, 2007 | 01:27 PM
numbnuts22715's Avatar
your radiator could be leaking, a radiator hose could be cracked, or have a whole in it.
There are a lot of things that can cause for you to lose coolant.
Old May 7, 2007 | 02:12 PM
Rikter's Avatar
Check your coolant as it is now with the car cold. If you need to top it up, do so.
Go out and drive your car. When it gets up to operating temperature drive it hard for a few mins.
Bring the car home and park it with some cardboard or something underneath. Make sure the ground is level. Let it sit for awhile then look underneath for a stain on the cardboard indicating a stain and whereabouts it's comming from. That'll point you in the right direction if it's got a leak and the cooland is making it to the ground.
-Rik
raju687
Sep 16, 2011 05:42 PM
hondaracin24
May 11, 2006 08:56 PM
94gsr18kid
Dec 29, 2004 08:12 AM
RAiMA
Jul 20, 2003 04:36 PM
Blue teg
Dec 17, 2001 07:21 PM
