syncro mesh
ok im going to buy that gm syncromesh cuz my syncros are getting fucked so im going to buy some right now and how do i put it in iin my tranny?? do i have to drain my tranny oil then add it again or do i just put it where my speedometer cable goes
You have to drain out the old fluid then refill it either from the fill hole or the vss.
there's a writup on the top of some of the forums.
I know there's one in the 92-00/
You need to drain the old fluid. I'd advise you on buying a length of tubing and funnel to fill it with into the proper fill hole.
http://www.c-speedracing.com/h...d.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazytalk »</TD></TR><TR><TD CLASS="quote">but do i fill the whole thing with syncromesh??</TD></TR></TABLE>
Nope, if it's a b-series 2.3 qts. D-series use 2.2
usually you just fill until it comes out of the fill hole.
Look at one of those write-ups, you'll know exactly what i mean.
Modified by ek forever guy at 12:51 PM 5/5/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazytalk »</TD></TR><TR><TD CLASS="quote">well what would be a better preference</TD></TR></TABLE>
What do you mean?
1) Buy the Synchromesh fluid (GM P/N 12377916). If you're buying it in quart containers, you'll need 3.
2) Read the links provided here regarding how to change the fluid.
3) Drain out the old fluid, and replace it with the new fluid, following the procedure outlined in the links.
That's all there is to it.
Here's a photo borrowed from member "migs" of the fluid you're looking for:
What do you mean?
No, the GM Synchromesh Friction-Modified fluid is only available at GM dealerships. The standard formula is available as Pennzoil Synchromesh fluid at most auto parts stores, but it is not friction-modified, which is what many people find helps alleviate grinding issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
Nope, if it's a b-series 2 qts. D-series use 2.2
Look at one of those write-ups, you'll know exactly what i mean.</TD></TR></TABLE>
No sir, B-series transmissions require 2.3 quarts.
If you fill it until it comes out the fill hole on the side of the tranny, the car MUST be level, on level ground and up on 4 jackstands.
JDMfrontedLS
17
Jun 23, 2006 11:08 AM
the.hamburglar
Jul 28, 2005 01:12 AM
