oil leak. need pointers
Old Jan 6, 2008 | 03:25 PM
98GSR-Turbo's Avatar
Default oil leak. need pointers
well i started my car up finally today. ran fine. then i heard lifter noise and noticed no oil pressure. so at that point i shut the car off and every drop of oil in the engine was on my garage floor. the front wheels are about 8 inches off the ground if that would have anything to do with it. could it be the little box that plugs into the block that has the pvc valve? any ideas let me know.
(note) the turbo is not on the motors yet. waiting on newer parts.
Old Jan 6, 2008 | 03:49 PM
97' Integra's Avatar
check the oil pressure line that hooks up to your oil filter, or your oil pan gasket
Old Jan 6, 2008 | 05:40 PM
Blahblah718293's Avatar
Default Re: oil leak. need pointers (98GSR-Turbo)
try to find where the oil is comming from?
Old Jan 6, 2008 | 07:55 PM
it appears that the oil came from the mid section of the engine. under the InMa and above the oil pan. I no some engines are equiped with an oil cooler but i dont think mine has one.
Old Jan 6, 2008 | 08:28 PM
jhammond_82's Avatar
Reject Papi
Default Re: oil leak. need pointers (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">try to find where the oil is comming from?</TD></TR></TABLE>
Old Jan 8, 2008 | 11:31 AM
could the head gasket have anything to do with it? there is no oil at all by the sending unit.
Old Jan 9, 2008 | 11:27 AM
what has pressurized oil running through it on the Intake mani side above the exhaust? I really need help with this one.
Old Jan 9, 2008 | 11:52 AM
scottland221's Avatar
Default Re: (98GSR-Turbo)
Are you positive there is a oil filter on it. Or if the turbo is not on yet is there and oil line or something not connected. There also could be a plug that is gone for like a oil pressure sensor or something like that. I would clean it all up, put more oil in it, have some one start it and just look down there, if it isnt the oil filter or something like that you should be able to see it pooring out of the motor. But obviously dont take that long cause you dont want to damage the motor. MAKE SURE YOUR OIL drain plug is in also. that happened to me once and it was not cool.
Serenity Now!
Jan 29, 2007 06:31 AM
Takashi1978
Feb 23, 2006 06:21 AM
mixxed
Jun 27, 2003 07:52 AM
TurbothisLS
Feb 11, 2002 01:00 PM
IVANITR
Nov 30, 2001 01:05 AM
