Need Help Quick Question
Old Jan 4, 2008 | 10:50 PM
JDMASTER EJ8's Avatar
Default Need Help Quick Question
My Tranny just started to grind into gears (lil grinds) and its hard to go into the gears. does anyone know what it could be i dont think its the tranny because i drove it the same day and it was fine.(i drive a gsr if that matters)
Old Jan 4, 2008 | 11:25 PM
VTEC_PRODUCTION's Avatar
Default Re: Need Help Quick Question (JDMASTER EJ8)
yea man, you are ripping on your tranny. its time for a rebuild. cold weather may also be the reason why its acting up. but either way sooner or later its gunna get worse if you keep beatin on it so time for a rebuild.
Old Jan 10, 2008 | 09:56 AM
Budget Racer's Avatar
Default Re: Need Help Quick Question (VTEC_PRODUCTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">yea man, you are ripping on your tranny. its time for a rebuild. cold weather may also be the reason why its acting up. but either way sooner or later its gunna get worse if you keep beatin on it so time for a rebuild.</TD></TR></TABLE>
Yo dood, I had the same problem with my old motor, and still then when I swapped out the new one. It ended up being the Clutch Master/Slave cylinder.
I recommend you replace them, or bleed your clutch. Trust me I was kicking myself when I realized it wasn't my tranny. I picked up used one's from the wrecking yard in Chula Vista.
Good luck man
crazybluecivic
Honda Civic (2001 - 2005)
Mar 8, 2008 06:58 PM
Chewy[Ek]
Apr 10, 2007 05:46 PM
hialeahzbg
Aug 30, 2005 12:07 PM
sLoWrAcEr
11
Feb 26, 2005 12:15 PM
nY's FiNeSt
19
Sep 13, 2003 10:55 AM
