94 engine
Old Jan 1, 2008 | 04:08 PM
Slick o9's Avatar
Default 94 engine
Alrite i have a quick question.
i plan on going lsV
i have a 98 teg.
today i got an offer on a 94 b18b long block..
my question is, because the block is obd1, will i need any special wiring for the just the block, the head will not be in use?
thanks.
Slick o9
Old Jan 1, 2008 | 04:33 PM
Slick o9's Avatar
bump?
Old Jan 1, 2008 | 06:13 PM
weavertime1's Avatar
Default Re: (Slick o9)
Well you will need to have the crank sensor installed, or jump it, which is possible and can be found on H-T. This sensor is used in OBD2 systems but not OBD1. So unless you go OBD1 (using a jumper harness and an OBD1 ecu), you will either need to install it or jump it. It can be found in your oil pump on the driver side of the engine near the oil pan. I believe it is a two wire sensor. Good luck, and maybe someone else can add anything they can think of.
Old Jan 1, 2008 | 06:18 PM
Default Re: (weavertime1)
Here is the link of someone with a similar issue, and the solution:
https://honda-tech.com/zerothread?id=52399
Turbo-GSR1287
Apr 12, 2008 08:20 AM
aw1234dude
Dec 7, 2004 01:27 AM
aw1234dude
Dec 7, 2004 12:56 AM
whoa its len 2
Oct 2, 2004 07:18 AM
Ehron
Oct 12, 2003 07:36 PM
