trunk and drivers side window
The trunk doesn't open as in.. Its locked? Or it doesn't stay up? Or what.
If it doesn't stay up you need to struts.
Power Window? First check your fuse. Then check connection to the motor. If that is all ok you need a new motor for the window
Try your key in. I'm not sure if these cars have a seperate key for the hatch/trunk. When I got mine the previous owner shaved the key hole in the trunk and took out the lock. If you hit the hatch release and it still doesn't open it might just be stuck, or the actual release is messed up. Could be the cable
