Need help identifying plug
Old Jan 2, 2008 | 03:21 PM
CRwreckz's Avatar
Default Need help identifying plug
The car is a 94 LS. I thought it was the IAC but the 2 wires coming from it go into the wire loom. This plug comes out of the loom where the IAC goes in. The plug as 2 wires (i believe they are red and yellow). I have 2 bare wires that come from the driver side frame rail....I assume they go to the plug but I'm not sure. Advice?
Old Jan 2, 2008 | 04:04 PM
HONDRETTI's Avatar
Default Re: Need help identifying plug (CRwreckz)
check for codes... it looks like your wires coming from your IACV harness are cut ? or is your harness simply not connected? im having trouble understanding...have you done anything to the car we should know about?
idk but see if this helps...https://honda-tech.com/zerothread?id=2082668
Old Jan 3, 2008 | 03:43 PM
CRwreckz's Avatar
Default Re: Need help identifying plug (HONDRETTI)
My brother just bought the car....has codes, I haven't checked them. The O2 was unplugged (I reconnected). Oil pressure sensor wire was broken (fixed that).
The 2 bare (cut) wires come from the driver side frame rail wire loom. The plug (pictured) comes out of the harness where the IAC wires go in. I think the cut wires are suppose to go to the plug but I'm not sure.
I'll take more pics later...kinda cold outside and the key is old.
Old Jan 4, 2008 | 07:17 PM
CRwreckz's Avatar
Alright....I think I have this figured out. I DL'd the sevice manual and it looks like the bare wires are for the power steering pump switch (ps has been removed and bypassed) and the plug goes to the evap (which is missing).
scubacamper
Mar 23, 2015 03:27 PM
KDvtec5757
Jul 13, 2009 04:49 PM
93egboosted
Mar 18, 2009 07:27 PM
GsDAteg
Oct 7, 2007 12:58 PM
Jonathan_ED3
Jun 21, 2003 04:16 PM
