this integra is hot!!!!!
Old May 18, 2008 | 09:00 AM
manuelesr's Avatar
Default this integra is hot!!!!!
ok i have a 1995 integra ls and im having an over heating prob.
originaly my temp, guage would start to pass the halfway mark if i let the car idle for to long, so i changed the thermostat and it heated up even faster after that so i put the other one back in and it worked the same way it did from the get go, then i was in the middle of down town chicago and a radiator hose blew out so i bought new hoses and another thermostat replaced them both,
it still over heates not as fast but the crazy thing is if i drive with my prm's over 3000 the temp guage will stay at half any ideas i was thinking water pump
Old May 18, 2008 | 09:06 AM
Blahblah718293's Avatar
Default Re: this integra is hot!!!!! (manuelesr)
its 1995, when was the last time you had a timing belt/water pump? id bet thats the problem.
i would also venture to guess your car is overdue for a coolant flush. if you dont do it every 2 years it will start to erode the inside of your engine away. including eating away at your water pump.
Old May 18, 2008 | 09:11 AM
spidy3's Avatar
Check for restrictions in radiator also. At idle the coolant might not be pushed hard enough to get through easily and when at 3k rpms the water pump pushes the coolant enough to get through the restriction
Old May 18, 2008 | 01:12 PM
butand50's Avatar
Is your fan working?
Old May 18, 2008 | 09:45 PM
manuelesr's Avatar
Default Re: this integra is hot!!!!! (butand50)
fan is fine im gonna change the water pump shoul i change the timing belt to?
Old May 18, 2008 | 10:18 PM
CeReal's Avatar
oh no. removing the crank pully twice is double the fun.
although, my concerns are the headgasket being cracked.
Old May 18, 2008 | 10:21 PM
manuelesr's Avatar
Default Re: this integra is hot!!!!! (CeReal)
iv got one more question what do you use to fill the trans with fluid
Old May 19, 2008 | 01:38 PM
CeReal's Avatar
a syphon pump abailable at the auto parts store.
imho, change the oil, and drain it into a tub where you can see if water is in the oil. headgasket problems are waaaaay more common than a failed water pump.
Old May 19, 2008 | 02:25 PM
manuelesr's Avatar
the only reason i say water pump is the coolant is **** brown and all the coolant lines are **** brown on the inside how do i flush the coolant? i will check the oil tonight
Old May 19, 2008 | 02:54 PM
tegman23's Avatar
my friend had the same problem it ended up being the headgasket..he was blowing hoses and things like that....the reason the temp stays down during the 3k range is probley because your getting a steady air flow to the radiator and its keeping the colant down in temp...
DumaDA
Jun 25, 2011 12:50 PM
untitled23
May 10, 2010 03:31 PM
nonvtec92
14
Nov 28, 2008 04:50 PM
UltimX
12
Jan 18, 2007 03:18 PM
sherman19
Jan 30, 2003 05:36 AM
