ctr camshaft
Old May 16, 2008 | 12:53 PM
lazyxmofo's Avatar
Default ctr camshaft
i got a sir gsr b18c .... i want to put in a ctr camshaft ? wondering if i got to do a valve adjustment ?
Old May 16, 2008 | 07:40 PM
DC2_2's Avatar
nope not necissarily. It wouldnt hurt though if you know how to do it
Old May 17, 2008 | 01:51 AM
J. Funk's Avatar
You dont have to
Old May 17, 2008 | 02:30 AM
Ketone's Avatar
Default Re: (J. Funk)
you don't have to, but I would do it.
Old May 17, 2008 | 07:11 AM
PACT man's Avatar
Default Re: (Ketone)
Ummm... last I knew you would if you wanted your car to run right. I know they have the same valve clearances between GSR/CTR/ITR but it does need to be done. When I installed my ITR cams in my GSR the clearances were all off.
Old May 17, 2008 | 07:26 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ctr camshaft (lazyxmofo)
Yes, you must do the valve adjustment. No two parts are identical. It is worth 15 minutes to make sure everything is in spec.
Old May 17, 2008 | 08:25 AM
Jdm_jay's Avatar
yes - you do have to, anytime you change out a cam o r jsut remove a cam you must check valve clearence after reinstallation.
intake 0.006mm
exhuast 0.007mm
Kr4nG
Nov 17, 2009 03:33 PM
JaydmEg
Mar 1, 2009 03:45 PM
markaria
Sep 27, 2001 08:37 AM
