DA Integra Clutch Problem
Old May 19, 2008 | 05:32 PM
dmingis's Avatar
Default DA Integra Clutch Problem
I have a 1992 Integra race car and was at the track this weekend and the clutch went bad. I removed the worn-out ACT pressure plate and 6-puck clutch, and put in a stock clutch disc and pressure plate from Acura. I left the release bearing, which according to ACT was an OEM type bearing.
The problem now is that the clutch disc won't disengage. The cable is adjusted all the way out -- as long as it can be -- and the clutch arm is bottomed out on the trans case when I hit the clutch pedal.
If I put the car in gear with the clutch pedal in, the car will move. If I hit the brake it won't stall. If I dump the clutch with the brake on, it will stall. So it seems like it's dragging a little tiny bit.
Any ideas what the issue might be? I'm baffled
Old May 20, 2008 | 07:28 PM
g2daturbo's Avatar
Default Re: DA Integra Clutch Problem (dmingis)
sounds like a bad pressure plate!!
Battle Stage
Jul 10, 2013 12:50 PM
k-hunter14
Sep 13, 2010 11:29 PM
tripledubz
Jan 26, 2008 07:05 AM
AZNracerx1989
Aug 9, 2006 08:34 PM
