Black dash conversion. Problems with low and high beams.
Old May 22, 2008 | 01:33 PM
silentdeath12886's Avatar
Default Black dash conversion. Problems with low and high beams.
99 Integra LS.
Today I finished converting my tan interior to a black interior. I was check all the electrical stuff to make sure it all works.
I turn on my low beams and the "high beam" light came on. I tried to flick the high beam switch and still the same. I turned off the headlight and flicked the high beam switch again and it went on like it should.
basically my problem is that the high beam symbol is on when I turn on my low beams. I can't confirm that my high beams are actually on, just the high beam symbol since my headlights are getting retrofitted.
I think it may just be the symbol going off and not the actual highbeams since I didnt touch any other wires except the dash wires. Any clues to where wires gom essed up or other issues?
Modified by silentdeath12886 at 2:55 PM 5/22/2008
Old May 22, 2008 | 02:46 PM
kicksremix2o6's Avatar
Default Re: Black dash conversion. Problems with low and high beams. (silentdeath12886)
did you try pushing it forward instead of toward you?
Old May 22, 2008 | 03:24 PM
Default Re: Black dash conversion. Problems with low and high beams. (kicksremix2o6)
yea, I tried every combo and still it had issues. I had to solder the blue, green plugs together since they were cut, but they were all connected correctly.
Old May 23, 2008 | 09:42 AM
allmotorek8's Avatar
how was it i gotta do the same to my dc ?
Old May 23, 2008 | 01:07 PM
redline760's Avatar
was the conversion a long process.
Old May 23, 2008 | 04:14 PM
mfef4dr's Avatar
Default Re: Black dash conversion. Problems with low and high beams. (redline760)
Im in the middle of doing mine right now. I had to take all the black interior out and it didnt seem to hard to put back in.
And to your question> check all the grounds under your dash.
Jimi Hondrix
Dec 20, 2016 04:10 PM
woodwardba0526
Honda Civic (2001 - 2005)
Mar 29, 2010 05:15 PM
Evan125
Dec 7, 2009 08:00 PM
rezzarect
Jul 28, 2007 08:22 AM
gr8 88
Apr 27, 2004 06:32 AM
