94-97 and 98-99 Headlights
I wanna get an Integra, but I noticed that the lights on the 94-97 is smaller and deeper in than the 98-99 Integras. Where as there are more bigger and closer out. Is there anyway if I get the 94-97 Integra, will I be able to convert it to the 98-99's? Will applying body kits need to be specially made to fit, or can I just get the 98-99 Body kits.
Re: 94-97 and 98-99 Headlights (XaznPKdogX)
yes you can convert it.
just FYI the reason it was changed is because owners complained that snow would build up in the recess and block out the lights..
in order to convert your 94-97 integra headlights you need, 98-21 headlights and front bumper. very easy to convert fast simple bolt on.
You said you wanted to buy an integra, so why not just buy the 98-01 model instead. why waste money on buying the 94-97 model when you want the 98+ front look.
1 Post
Re: 94-97 and 98-99 Headlights (SPOON SPEC DC2)
...but it's also a few hundred bucks, which could probably be spent more productively elsewhere (although the 98-01 look is sweet).
The differences I found between a 94 GSR to a 98 GSR is almost 4000 and more,
If I do buy the 98 GSR, of course I get the headlights and bumper, but I will eventually change the bumper for a body kit from BOMEX! Since I am going to change the front, why not just get the headlights and the kit?
Anyone know where I can get healights?
Is there any other difference along the body of a 94-97 to a 98-01 Integra? Has anyone tried to change the lights to the newer ones?
Links would help too.
Just the bumpers, tail lights, and headlights.
BTW, does anybody with an older GenIII Integra have an antenna that leans inward instead of standing straight up? Mine leans in ('95 GS-R) and my friend's stands straight up ('01 ITR).
Re: 94-97 and 98-99 Headlights (97blackteg)
hey, you also need one more piece, many ppl neglect it but it's important to have it. front bumper foam absorber for the 98+ is bigger than the 94-01 ones. So if some lady trys to park and back into ur front, you'll need a new cover. You can call ACURA and they'll tellyou that the part number is different for them.
XaznPKdogX
01-15-2002 12:57 PM
