squeeking sounds
Old Jan 13, 2002 | 12:02 PM
acuraLSSE95's Avatar
New User
Default squeeking sounds
when I speed up, then press on the brake gradually, I hear a little low squeeking sounds, doesn't always happens. Most of the time when it happens, is when I'm speeding up and gradually braking and turning my streering wheel to the alittle right. maybe to the left too but I havent' tried that. If I'm driving straight forward, doesn't matter at what speed, and I press on the brakes gradually, it will not happen.
Old Jan 13, 2002 | 03:44 PM
eh-D's Avatar
Default Re: squeeking sounds (acuraLSSE95)
Sounds like the wear indicators dragging on your rotors.
How long has it been since you replaced the pads?
Old Jan 14, 2002 | 08:10 AM
New User
Default Re: squeeking sounds (eh-D)
what does that mean? give me more details
Old Jan 14, 2002 | 08:17 AM
speedymon's Avatar
The wear indicators just tell you when you pads are in need of replacement. It's so that they don't wear down without you knowing and you go careening off of a mountain road.
Old Jan 14, 2002 | 08:46 AM
New User
Default Re: squeeking sounds (speedymon)
i c, so do i have to change 4 of them?
[Modified by acuraLSSE95, 10:49 PM 1/14/2002]
Old Jan 14, 2002 | 09:12 AM
RacingE_Teg's Avatar
Inspect the brakes at all corners. Check to see if the fronts and/or rears need replacing, then go from there...
Old Jan 14, 2002 | 11:50 AM
ken's Avatar
ken
Does it squeak at all when you are not breaking, like when the brakes are still cold? I had almost the exact same problem coming from my front passanger side. Problem was that the caliper was worn and wouldn't release all the way. Cost $300 to have the whole front end overhauled (new calipers, resurface rotors, quality pads).
Old Jan 14, 2002 | 01:51 PM
New User
Default Re: squeeking sounds (ken)
it doesn't squeek at all if I"m not braking. It only squeeks if I gradually brake, Not always though. Only on the right side for now. I think.
potatostix
Oct 26, 2005 05:54 AM
MapofurheadCrx
Feb 28, 2005 03:07 PM
Lazydsm
Dec 9, 2003 08:35 PM
Red94Sedan
Mar 7, 2003 10:00 AM
bhcvc
Jan 14, 2002 07:31 PM
