a problem with not getting to normal engine temp
Old Jan 16, 2002 | 10:19 PM
Volcom's Avatar
Default a problem with not getting to normal engine temp
Heres the problem. 94 integra RS with just a short ram intake. It seems like everywhere I drive, the engine has a hard time getting to normal engine temp. But the bigger problem is when I drive up and down big mountain passes. I live in CO and am constantly driving up I-70 which starts at 5000 feet or so and ends up at almost 11500 ft. When I am driving down the pass, my enigne temp drops so low that the heater in the car doesn't blow hot air and the oil temp gauge is sitting so low that it looks like I just started the car. Any suggestions? Maybe put the stock piping back on for winter and the short ram for summer? Am I using more fuel than I should be since the engine performs best at normal temps? Thanks
Old Jan 16, 2002 | 10:26 PM
Stu's Avatar
Stu
New User
Default Re: a problem with not getting to normal engine temp (Alphanumeric)
Intresting... I live in Golden, and installed an AEM CAI and have never had trouble. Hope you fix the problem!
Old Jan 16, 2002 | 10:34 PM
Volcom's Avatar
Default Re: a problem with not getting to normal engine temp (Stu)
yea its super weird. My gf gets all pissed off when we go up the mountain because of all the noise from the intake. I personally like it. Then she gets even madder when the heater stops blowing hot air. So your running a cold air intake in colorado. Man, you have some big ***** doing that to a daily driver here.
Thanks for the reply
Old Jan 16, 2002 | 10:41 PM
Stu's Avatar
Stu
New User
Like a month after I did it, I gave this salesman a ride in one of those huge rainstorms where the highway floods, scared the bejesus out of me. I've never had any problems though. Athough I do have a friend who seized his motor on his Z24 Cavileir doing the same thing. Sucks for him!
Old Jan 16, 2002 | 10:42 PM
GTEater's Avatar
it may be just that, coincidentely, your thermostat is stuck open.........my gsr has the same problem.........stays super cold on the highway, and only gets to normal temp when at idle.....your probably running cooler up the mountain cuz the air is thinner and colder at high elevations
Old Jan 16, 2002 | 10:46 PM
Vtec integra's Avatar
it probably is the thermostat stuck wide open. when you take long rides on the highway does the temp drop?
Old Jan 16, 2002 | 10:47 PM
Volcom's Avatar
Default Re: a problem with not getting to normal engine temp (GTEater)
Around town, i'm sitting at a fine temp, running the car hard up the pass, it's fine. It just does it when I go downhill and really don't press on the gas all that much. How are is it to replace a thermostat? Thanks
Old Jan 16, 2002 | 10:53 PM
is your coolant running low?
its not that hard to replace the thermostat
Old Jan 17, 2002 | 06:19 AM
HiRevn's Avatar
Mine did the same thing. My thermostat was stuck open. I replaced it and now it warms up really quick. I'm just guessing, but I would assume if you're running too cold it would affect your fuel mileage too.
Old Jan 17, 2002 | 06:30 AM
GSRaCeRbOI's Avatar
try replacing your thermostat... http://www.bseries.net/html/garage/thermo.php
Cimburke23
40
Feb 12, 2011 11:48 AM
civicsi888
Oct 19, 2007 07:09 AM
wardstar
Jun 24, 2004 06:22 PM
Buckshot
Oct 26, 2002 02:34 PM
jabenne
Apr 4, 2002 05:50 PM
