Cooling Problem
Old Jan 16, 2002 | 10:40 AM
delSolLS's Avatar
Default Cooling Problem
Just replaced the thermostat on my 95B18B. Now in the cold weather it takes forever to warm up. Used a Stant 180 degree thermostat.
Defective thermostat or POS? Should I get an OEM from Acura?
Old Jan 16, 2002 | 10:50 AM
91DA9's Avatar
Default Re: Cooling Problem (delSolLS)
I would think it is the thermostat. Did you refill with correct coolant/water mixture?
Old Jan 16, 2002 | 01:06 PM
delSolLS's Avatar
Default Re: Cooling Problem (94IntegraGSR-OVR)
Yes, drained and filled coolant, bleed while cold. Warmed up engine and bled coolant again and refilled.
It just sucks that a brand new thermostat isn't working- takes longer to warm up and once I start driving, temp goes back down to just above the C on the guage.
Especially with the cold weather.
Joshable14
Jul 20, 2015 10:10 AM
crxfreak1117
Jan 28, 2008 04:07 PM
superstud
Oct 14, 2004 12:44 PM
superstud
Mar 14, 2004 08:54 PM
pelotudo
May 13, 2002 11:16 AM
