lowering or upping compression on a ls..
Old Oct 21, 2002 | 12:50 PM
allmotorls95's Avatar
Default lowering or upping compression on a ls..
what are the advantages of this im confused and what are the most common ways of doing this.
Old Oct 21, 2002 | 01:27 PM
Adriano's Avatar
Default Re: lowering or upping compression on a ls.. (allmotorls95)
lowering c/r is better for forced induction. you need to change the piston(right way) or put in a thicker head gasket(cheap way).
higher c/r is for na/all motor setup. This requires changing pistons.
Old Oct 21, 2002 | 05:40 PM
Steve-o's Avatar
Default Re: lowering or upping compression on a ls.. (brryder)
low comp. great boost high comp. great all moter n20 friendly but leave it the same and have the both of both worlds! but you might want to rais it to at least 10.6:1 or 10.0:1
[Modified by Steve-o, 6:41 PM 10/21/2002]
JDM BR33D
10
Aug 9, 2018 08:03 PM
tobe1424
Sep 2, 2006 09:23 AM
Flexin5
Aug 31, 2004 02:58 AM
DrPhang
Apr 30, 2002 04:12 AM
type autox
Sep 20, 2001 04:44 PM
