Is a FPR worth it?
Old Feb 17, 2003 | 06:38 PM
acatak's Avatar
Default Is a FPR worth it?
My mods are listed in my sig. I will also have a coursound cat, and apexi vafc or fields sfc vtec controller soon. My question is do I really need a FPR? I will be taking my car to the dyno, but I dont know if it is worth spending the money on a FPR.
Old Feb 17, 2003 | 06:40 PM
jdhealy's Avatar
Default Re: Is a FPR worth it? (acatak)
i have been wondering the same thing because my car is a little harder to start and wants to die out at low rpms
Old Feb 17, 2003 | 08:10 PM
Tweakmeister's Avatar
if you're going to the dyno then yes, a B&M is a good/cheap one to get.
Old Feb 17, 2003 | 08:13 PM
B00ST2nR's Avatar
Default Re: Is a FPR worth it? (Tweakmeister)
Yeap. That's what I have.
Old Feb 17, 2003 | 09:42 PM
EkREV's Avatar
New User
since you plan on purchasing an vafc/fields, you will be able to adjust your fuel w/ any of the two units.
Old Feb 18, 2003 | 06:57 AM
acatak's Avatar
Default Re: Is a FPR worth it? (EkREV)
I realize that I can fine tune the fuel map with the vafc or fields sfc. and a fpr cant really fine tune but lean out or richen throught the whole powerband. Since I can fine tune with the vafc, will I rally need a fpr?
Old Feb 18, 2003 | 09:00 AM
EvilIntegrationLS's Avatar
b&m fpr
Old Feb 19, 2003 | 05:29 PM
Mr.Integra's Avatar
Default Re: Is a FPR worth it? (EvilIntegrationLS)
you only use FPR if you need more fuel but don't want to spend money on larger injector. Your injector life will also be shortened and there is a greater chance for the fuel to leak past the injector seals.
Its better to get larger injectors and having a stand alone unit control the duty cycle.
Old Feb 19, 2003 | 05:33 PM
threatcon13's Avatar
New User
Default Re: Is a FPR worth it? (Mr.Integra)
good point. this is where hondata comes in...not a stand alone...but 10x better for tuning than vafc..and since your car is a 95, about the same price.
Wes90civic
Jan 11, 2004 11:04 AM
97coupe
10
Oct 8, 2003 08:05 PM
REVolution
Jun 17, 2002 08:59 AM
capcon83
Mar 11, 2002 05:54 AM
01itr518
Jan 11, 2002 06:25 AM
