phantom grip?
Old Feb 15, 2003 | 01:51 PM
94gsrsedan's Avatar
Default phantom grip?
Does anyone have a phantom grip lsd on there teg if so what do you think about it?
Old Feb 15, 2003 | 01:54 PM
ragejed's Avatar
Default Re: phantom grip? (94gsrsedan)
I hear they are crap and they destroy trannies...I dont know ANYONE that uses them.
They arent real LSDs either. They just lock the differential completly
Old Feb 15, 2003 | 02:19 PM
Micro-R's Avatar
I used one last year in my Pro-Stock integra and it dropped the 60' times from 1.9 to 1.5. I also have a customer that uses one in his Integra that he Solo races and it works very good. It is designed like RWD differentials like Eaton and Moroso.
Old Feb 15, 2003 | 02:30 PM
MrFatBooty's Avatar
Default Re: phantom grip? (Micro-R)
That's the first good thing I've ever heard about a Phantom Grip.
From my understanding, it installs inside of (rather than in place of) your stock differential and converts it into a sort of rudimentary locking diff. I would stay away personally, as I have seen a number of diffs ruined by having these things installed on them.
Old Feb 15, 2003 | 02:37 PM
au-gsr's Avatar
Default Re: phantom grip? (MrFatBooty)
they cost about two hundred and for another 150 or so you can have a type r lsd off of ebay. which is the way to go if you ask me. our trannies are very picky and i would stick with oem parts if at all possible, and in this case it is. if you are going to do a lsd get a lightened flywheel and possibly a final drive. it's best to dao all the work you wnt to on a tranny at one time. that way you won't hve to pay 400-800 each time they open it up. if your car is relatively low mileage spend the money on the upper block first because later down the road when the clutch neeeds to be replace you will have to open the tranny again.
Old Feb 15, 2003 | 03:19 PM
94gsrsedan's Avatar
Default Re: phantom grip? (au-gsr)
ive order a act extreme clutch,lighten flywheel,short shifter,and new shift brushings, i was getting it all done at once.
Old Feb 15, 2003 | 04:12 PM
Micro-R's Avatar
i change my mind and think you should not get the Phantom Grip unless you already bought it. Haha!
Old Feb 15, 2003 | 04:16 PM
ragejed's Avatar
lol
Old Feb 15, 2003 | 04:17 PM
au-gsr's Avatar
Default Re: phantom grip? (ragejed)
that's funny shift bushings and a short throw shifter have nothing to do with tranny work. they are independent and will stay on the car wether the tranny is there or not
Old Feb 15, 2003 | 04:39 PM
threatcon13's Avatar
New User
LOL! good one.
Old Feb 15, 2003 | 04:45 PM
Micro-R's Avatar
Default Re: phantom grip? (Threatcon13)
i really did. i know 94gsrsedan and i'm just messin with him.
Old Feb 16, 2003 | 09:33 AM
TimoneX's Avatar
New User
Random Slip? Don't waste your $$$.
Old Feb 16, 2003 | 09:58 AM
94gsrsedan's Avatar
Default Re: phantom grip? (TimoneX)
Crower valuetrain? Don't waste your money
Old Feb 16, 2003 | 10:25 AM
TimoneX's Avatar
New User
lol Too late he already bought the random slip.
Run a search on Phantom Grip...I don't think I'm the only one that thinks little of them. It's essentially the same thing as a welded differential, only you get to pay $$$ for it.
Old Feb 16, 2003 | 10:27 AM
. o 69 o .'s Avatar
im gonna quote Locash
"works so good, you hardly know its there"
Old Feb 18, 2003 | 12:34 PM
94gsrsedan's Avatar
lol to bad u didn't your top end with cheap parts
Old Feb 18, 2003 | 06:07 PM
TimoneX's Avatar
New User
Cheap parts that perform well are kewl. Cheap parts that are the same as welding your differential and break all the time(Phantom Grip) are not so kewl. Just ask around buddy...or better yet open a brand new Phantom Grip box. This is a lock, nothing more. It locks your differential together, you'd be better off welding it and saving the money for a real differential Quaife, Kaaz, or ITR. You go ahead and get your Phantom Grip and bring your car on over and we'll see who's carload of "cheap" parts get to the end of the 1320 first.
Old Feb 18, 2003 | 08:00 PM
New User
why are you talking ****? hes trying to help you out idiot youre the one asking about the phantom, obviously YOU are the one trying to race w/ cheap, INEFFECTIVE parts moron.
Old Feb 18, 2003 | 08:22 PM
TimoneX's Avatar
New User
Really, I don't understand why you're jumping down my throat because I insulted a part you were asking about. A part nobody has anything nice to say about. I'm done with this thread anyway, if you want a phantom grip "wanna be" LSD then more power to ya, but it's extremely expensive for what you get and it's money much much better spent going toward a new or used ITR LSD.
Old Feb 18, 2003 | 09:53 PM
DeafNgari's Avatar
ITR LSD are very very nice, but if you can afford go w/ quaife... they are certainly more expensive but have a lifetime warrenty that covers racing also. Its engagement is a little smoother also. Both are great, not sure which one will find its way into my tranny yet.
Old Feb 18, 2003 | 10:12 PM
Rayman's Avatar
Default Re: phantom grip? (DeafNgari)
Phantom grip = Junk. And breaks axles.
Old Feb 20, 2003 | 04:14 AM
BabyDaddy's Avatar
Default Re: phantom grip? (Rayman)
Breaking axles... I don't think so. Breaking the stock differential cast maybe so.
Phantom Grips DON'T lock your differential. They are available with different spring rates between the plates depending on how much transfer or lack of transfer you desire.
[Modified by BabyDaddy, 3:51 PM 2/20/2003]
Old Feb 26, 2003 | 01:22 PM
Bontke's Avatar
Default Re: phantom grip? (BabyDaddy)
anyone read the april issue of Sport Compact Car where they installed it in a neon? They gave it a good review. Now we wait and see how it does. It is questionable but effective. Only thing I worry about is what about the friction? You have the phantom grip rubbing 2 pieces of the spyder gears making heat. THey also didn't mention any type of material or coating that makes it safe to rub the spyder gears against the phantom grip. I wonder if you get metal shavings? I know I wouldn't want metal shavings in my trans bearings. Can anyone comment (with experience preferably) on metal shavings or the wear and tear on the spyder gears?
Old Feb 26, 2003 | 03:36 PM
94gsrsedan's Avatar
94 gsr sedan
aem cai,dc sports 4-1,skunk2 cams,cam gears,values,itr value springs,coilovers,short shifter,field vtec controller,tokico 5 ways, black ss 15" rotas,act extreme clutch,lighten flywheel, "phantom grip" which works great!
Build bottom end coming soon Big **** your car can beat mine. Wow then you can tell all your friends u beat a 4 door 140k miles on it cool.
Old Feb 26, 2003 | 03:43 PM
TimoneX's Avatar
New User
I'm delighted you're happy with it. For what you likely paid you could've nearly bought a real LSD however.
