Question about using CTR intake cam
Ok, so after I get a few more "need" type mods, my next "want" type mod is going to be a CTR intake cam (and possibly CTR or ITR exhaust cam, doesn't matter right?).
Anyway, a talked about it with a homie and he told me that because CTR's have a higher vtec engagement point, the cam won't work well in my B18C unless i get cam gears and a vtec controller. Makes sense to me.
My question is, is this cam really worth the extra stuff? I could drop ITR cams in there no problem right? All I might need are cam gears. Am I thinking correctly here?
Thanks in advance. J
you can get more power out of your stock cams with just a v-afc and cam gears on the dyno.
You could drop in the ITR's and not change the rev limit or anything and get a little horsepower. tuning will get you more.
I don't believe I'll have any luck getting on a dyno.
Then the ITR/CTR cams are the cam of choice --- I would say that they need as little dyno tuning as any cam possibly could. You also do not need cam gears to run them --- my bud RedStarGSR ran them for a good month quite nicely w/o anything but the cams.
Cool.
So, back to my original question. Am I better off dropping in ITR in/ex cams? From what I understand that CTR intake cam is only going to hurt me unless I get a vtec controller so I can bump engagement up to 6000 or whatever it is for a CTR.
Yeah, I've never heard of anyone amateur like myself getting dyno time in Hawaii. I don't even know where they have one here. I know it exists though, cause my friends' best friend blew up his 10 sec eclipse motor on it last month. lol
[Modified by B18Chillin, 10:29 PM 2/17/2003]
Interesting.
Ok, well, dyno tuning is more than likely not going to be available to me at all. The best I can do is get everything set up and make sure the car runs well enough to get to the track. Meet up with friends there and keep doing runs til I find something I like.
Looks like I'm going save up for the vtec controller first, then go for the cams.
you don't really need a dyno...
just a couple of sensors and the like (datalogger, etc.)
don't worry about it...drop in the ITR's and be done with it.
Phatch99
Jul 28, 2004 12:04 PM
