Need some advice.
Old Feb 18, 2003 | 04:34 PM
MooreBoost's Avatar
Default Need some advice.
Im going to pick up some cam gears from Chet friday, good guy btw. I then planning on putting in cams later. My question...Do I need fuel managment? He has a Field vtec controller for 200. Should I go that route or spend the extra dough on a VAFC? Thanks all.
gmoore
Ohh- my setup- 00 GSR, JRSC@10psi, btc, map mod i/h/e, clutch/lsd/flywheel, msd ignition.
Old Feb 18, 2003 | 05:24 PM
Rory Breaker's Avatar
Default Re: Need some advice. (gmoore379)
Go Hondata if you havent already...what fuel setup are you running now?
What cams do you plan on running?
Old Feb 18, 2003 | 05:35 PM
MooreBoost's Avatar
Default Re: Need some advice. (newgsrdriver)
Its just the boost upgrade from JR. Pump and boost dependant regulator. Im not positive on the cams, maybe Skunk stage 2's.
gmoore
Old Feb 18, 2003 | 06:39 PM
Youre running the JR upgraded blower pulley and you see 10PSI with it? Stock injectors, stock JR FMU???
And you want to run Skunks with the blower??? Have you researched any of this?
First off, the cams wont help. An ITR exhaust cam tuned properly can give some good gains, but the Intake cam will do nothing but harm for you. Secondly...running that much boost with the blower on stock injectors and the JR FMU...youre totally asking for trouble. You should address that ASAP.
Pr0j3ctxH@tchx90
Apr 20, 2007 03:38 AM
Civichatch2k
Jul 8, 2004 07:52 PM
advance concepts
Jul 16, 2003 03:16 PM
White S2k
Dec 1, 2002 06:35 AM
1fastGSR
Feb 27, 2002 04:51 PM
