auto x
Old Feb 16, 2003 | 08:57 PM
au-gsr's Avatar
Default auto x
check out the rubber that i 'm spraying!!
[Modified by au-gsr, 10:57 PM 2/16/2003]
Old Feb 16, 2003 | 09:04 PM
threatcon13's Avatar
New User
Default Re: auto x (au-gsr)
great job knocking down all those cones. post this in members corner, doesnt belong here.
Old Feb 16, 2003 | 09:40 PM
Al Bundy's Avatar
Default Re: auto x (Threatcon13)
hahaha
Old Feb 17, 2003 | 06:37 AM
beefpigs's Avatar
Default Re: auto x (Al Bundy)
aaaahhh I believe the cones are laying down on purpose and pointing in the direction that he is supposed to be running. Well that's the way they do it for autoX around here.
Old Feb 17, 2003 | 07:04 AM
au-gsr's Avatar
Default Re: auto x (beefpigs)
beefpigs is right and if threatcon ever got out of his room and raced, he would know that's how an auto cross track is set up. any ideas on how to stop the body roll in that picture? and threatcon the members corner is no more, thought you knew that!
[Modified by au-gsr, 9:06 AM 2/17/2003]
Old Feb 17, 2003 | 07:35 AM
StyleTEG's Avatar
ITR rear sway bar will take some of that roll out of your body
Its a very cheap and effective mod!
Old Feb 17, 2003 | 08:29 AM
Dan GSR's Avatar
nice
was this your first event?
Old Feb 17, 2003 | 08:31 AM
beefpigs's Avatar
Default Re: auto x (StyleTEG)
First thing you should do (with the BSQ kit). Cheap and the best suspension mod you can do.
Old Feb 17, 2003 | 08:32 AM
Solracer's Avatar
True but if he is running in the stock class that will bump him to street prepared or STS.
Old Feb 17, 2003 | 08:40 AM
94TealGSR's Avatar
Default Re: auto x (Solracer)
I always wondered how they would notice something like this. The GS-R and Type R swaybars aren't dissimilar in appearance... is it just an honor system or what?
Old Feb 17, 2003 | 09:04 AM
StyleTEG's Avatar
Definetly it will, but he asked how to remove some bodyroll, so I figure either he is already in STS or is planning on modifying his car anyways.
Old Feb 17, 2003 | 10:16 AM
5-SpeedFreak's Avatar
New User
If anywhere, this post belongs in the autocross forum. Who cares though. I love seeing pictures of Integras whoopin at the autocross!
My next whoopin session is in in 2 weeks.
[Modified by 5-SpeedFreak, 11:19 AM 2/17/2003]
Old Feb 17, 2003 | 10:24 AM
Solracer's Avatar
Default Re: auto x (94TealGSR)
Mostly honor system, however, with the type r sway bar however the mounts shocks and LCA's are difernt right? and people who are paying attention could figure it out.
Old Feb 17, 2003 | 10:48 AM
Volcom's Avatar
Nope, just the swaybar is different. Au-gsr is running STS so the upgraded swaybar should be his next mod. Here's the same turn at Coors Field in Denver in my car. Stock shocks on stock springs with an ITR rear swaybar!!!!!!
Old Feb 17, 2003 | 10:51 AM
ridnmyhonda's Avatar
Default Re: auto x (Volcom)
here is me in my old car
Old Feb 17, 2003 | 01:46 PM
au-gsr's Avatar
Default Re: auto x (ridnmyhonda)
yeah i have the bsq kit gonna do the r bar for the next time around. the car is in STS though i have i/h/e and spc lca's upper control arms as well as koni's on ground controls. i might have a high flow cat too which will throw me into STX, we'll see though i need a job first!!
Old Feb 17, 2003 | 02:33 PM
InspiredRacer's Avatar
Someone show that car how to rotate. Body leeeeeeann
rear sway bar and take the front strut bar off
Old Feb 18, 2003 | 01:18 AM
New User
Default Re: auto x (InspiredRacer)
Take the front strut bar off?
Old Feb 18, 2003 | 07:12 AM
Daysleeper's Avatar
What is a BSQ kit???
Old Feb 18, 2003 | 07:40 AM
StyleTEG's Avatar
Yeah, I don't understand the front strut bar either?
Maybe you ment the front sway bar? which would result in more oversteer? (although it would probably end up in way to much oversteer)
Old Feb 18, 2003 | 07:51 AM
JSR3STS's Avatar
I own a 95 integra, now i just purchased a GSR front 24 mm sway bar and endlinks, it will fit my 95 RS correct???
Thanks jason
Old Feb 18, 2003 | 07:56 AM
Solracer's Avatar
Actually a lot of the CRX guys remove the front strut bar and it does seem to help the car rotate more.
Old Feb 18, 2003 | 03:01 PM
Weston's Avatar
Type-R sway bar all the way. It'll reduce the roll and make it rotate much easier. Looks like you were taking that turn pretty wide. Was it understeering on you?
Old Feb 18, 2003 | 03:04 PM
Weston's Avatar
Uh, those are called pointer cones. How could he have possibly knocked over the cones BEFORE he got to them!?
Why do you have to be such a ***** all the time?
Old Feb 18, 2003 | 03:05 PM
10K2HVN's Avatar
May i ask what kind of lip that is...?
